Trans leak
Old Feb 17, 2004 | 08:55 PM
cragger's Avatar
cragger
Default Trans leak
I parked my '84 in the garage to do some long needed work. It hasn't been started in two weeks. Yesterday, there was a large puddle of trans fluid beneath it...and it wasn't there the day before. What would cause the tranny to all of a sudden leak fluid Im talking at least a qt or better) after not being run for two weeks? :nopity
Old Feb 17, 2004 | 09:00 PM
Pete K's Avatar
Pete K
Default Re: Trans leak (cragger)
This could be the convertor draining the fluid that sits above the hub. Happens a lot to cars that sit. I hope it is that simple. If not I see wreching in the future. Keep fingers crossed. :thumbs:
Old Feb 17, 2004 | 09:30 PM
cragger's Avatar
cragger
Default Re: Trans leak (Pete K)
OK....but where does it leak from? The filler tube, front seal...?
Old Feb 17, 2004 | 09:35 PM
69vetteracer's Avatar
69vetteracer
The torque converter can drain enough to actually overfill the trans. Look for it coming out of the vent on top. If you had another bad seal it would leak all the time. :chevy
Old Feb 17, 2004 | 09:39 PM
Pete K's Avatar
Pete K
Your leak could be from any seal in the tranny but if you are lucky and my guess is right gravity forces fluid in top half of converterthru hub and past front seal. look under at convertor cover it should be wet. When my vette sits about 3 weeks this happens . (fingers crossed) :jester
Old Feb 17, 2004 | 09:40 PM
Pete K's Avatar
Pete K
:iagree:
Old Feb 17, 2004 | 10:27 PM
cragger's Avatar
cragger
Thanks for the prompt reply....it was exactly as you said.
To Trans leak
