I read that only gasoline, not oil, should be used to lube injector seals when installing (also never use silicone lube) on the rail. Can anyone chime in to confirm/deny this claim? Oil would be easier...but I always use gasoline.
Gasoline - Yikes! - Can't say I've ever seen that recommended in any service manual, though GM recommends transmission fluid to lube TBI injector seals. I also suppose a drop or two of gasoline that might drip onto the manifold would evaporate long before it caused a problem, but the idea is to lubricate the O-ring so it isn't damaged during installation and use. So if gasoline does the job, so does water or spit (which probably have a slower rate of evaporation). Stick with oil.
