A.I.R. pump elimination question
Feb 24, 2004 | 06:07 PM
I'm removing my A.I.R. pump and was wondering what other have used to plug their tubes on the exhaust manifolds. If you used a threaded fitting where did you get it from?
Feb 24, 2004 | 07:02 PM
Re: A.I.R. pump elimination question (86Pacecar)
I took mine to my exhaust guy had him cut the tubes off and weld the holes shut
Feb 24, 2004 | 07:19 PM
1/2" npt pipe caps
:cheers:
I cut mine off and mig welded manifold while still installed
:seeya
[Modified by AGENT 86, 4:21 PM 2/24/2004]
Feb 24, 2004 | 07:48 PM
Re: A.I.R. pump elimination question (AGENT 86)
Quote:
1/2" npt pipe caps
:cheers:
:seeya
Yepm welding them shut would be best, plus clean it up a lot. Its amazing how much tubing there is in that AIR system.
Feb 24, 2004 | 08:59 PM
Re: A.I.R. pump elimination question (rsafier)
Quote:
1/2" npt pipe caps
:cheers:
:seeya
that's what i did . plus removed all of the egr system! :yesnod:
