surging problems
Old Feb 25, 2004 | 07:47 PM
timmytcc's Avatar
timmytcc
Default surging problems
I have a surging problem when holding at a constant speed and or RPM, also on deceleration. feels like the car is bucking. stange part is there is plenty of power when accelerating. Have had this to 2 shops + GM tech , and no results.
Old Feb 25, 2004 | 07:54 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default Re: surging problems (timmytcc)
I haven't a clue, but welcome to the forum........these guys know lots of stuff and, if they can, they will help you................
:seeya
Old Feb 25, 2004 | 11:44 PM
rick lambert's Avatar
rick lambert
Default Re: surging problems (brdd)
Have you checked your fuel filter? Cats? Cats can really give some wierd reactions if they are getting clogged! Good Luck and post your find! :seeya
Old Feb 25, 2004 | 11:49 PM
timmytcc's Avatar
timmytcc
Default Re: surging problems (rick lambert)
dropped off car today to vette specialists, say it's most likely not fuel related, because it surges on deceleration, you said the same thing he did about a possible clogged cat. hope thats it.
Old Feb 26, 2004 | 12:46 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
:iagree:
Old Feb 26, 2004 | 08:51 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: surging problems (vinnies87)
have you done any ECM/PCM reprogramming? What grade of fuel are you running? I Also check your fuel injectors.. I injector stuck shut would cause cyl. to run lean.. and surge.. DANGER DANGER DANGER! Also, Check for operation of the O2 sensors.. if you have a scanner log some data and we'll check it out for you.. if not but a voltmeter on the 02 wire while the engine is idling (warm idle in closed loop) and the readins should vary pretty rapidly.. between 100mv-800mv 450-500mv is perfect stoich..less is lean more is rich.. however you must look at the net avg. of the swing - not just instintanious readings. could also be a fuel pump or clogged fuel filter.. malfunctioning MAP, IAC or evaporator purge system.. could also be bad spark plug, wire or coil.. theres a lot to look for.. start eliminating possiblitues..
Old Feb 26, 2004 | 09:14 AM
ittlfly's Avatar
ittlfly
Default Re: surging problems (BluByU)
:iagree: Just to add, I think BluByU means "canister purge system" not "evaporator purge system".
Old Feb 26, 2004 | 11:03 AM
timmytcc's Avatar
timmytcc
Default Re: surging problems (ittlfly)
where to begin, thanks for the help evryone
Old Feb 26, 2004 | 01:43 PM
Z06_BluByU's Avatar
Z06_BluByU
correct.. :grouphug:
Old Feb 26, 2004 | 01:51 PM
ittlfly's Avatar
ittlfly
:iagree: Just to add, I think BluByU means "canister purge system" not "evaporator purge system". correct.. :grouphug:
No problem. We're all getting old. :D
Old Feb 26, 2004 | 02:24 PM
Z06_BluByU's Avatar
Z06_BluByU
I dont think the EPA (or my pocket book) with a evaporator purge system.. especially in these R12 cars.. :lolg:
Old Feb 26, 2004 | 06:47 PM
ittlfly's Avatar
ittlfly
Maybe you could run your " R-12 purge tubes" in front of the windshield. Give the stop light competition a little "spray" like the big straps with NOX. :D
To surging problems
