Digital heat/ac question
Old Feb 27, 2004 | 12:54 PM
twofingerdoug's Avatar
twofingerdoug
Cruising
Default Digital heat/ac question
Hi, I'm brand new, so far I've just been reading past topics. My heater/ac is stuck on 90 degrees, I cant get it to cool down at all, the fan works fine but the cool button is not doig its job. Any suggestions?
Thanks in advance.
Old Feb 27, 2004 | 01:17 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Default Re: Digital heat/ac question (twofingerdoug)
There's a circuit board that controls that panel.
It may be fried.
I had to replace mine once.
Did the trick.
Good luck.
Matt383
Old Feb 27, 2004 | 05:58 PM
dzierke's Avatar
dzierke
Default Re: Digital heat/ac question (Matt383)
My heater/ac display ajusts from 65 to 90 degrees but doesn't make any change in temp. It can be cold out with the engine at operating temp (180) and yet it still blow cold air. Then suddenly it blows heat into the car. After it's nice and warm I can't cut back the heat. Haven't had time to install a new heater valve yet but I don't think that it will fix regulating my temp controls.
Old Feb 27, 2004 | 08:34 PM
chb88's Avatar
chb88
You can get a new heater control module from "The Last Detail" for about $125 or you can try to clean the contacts on your existing one. There is a Tech tip I used last year that fixed the very same problem. https://www.corvetteforum.com/techti...D=92&TopicID=2
Its not hard to do, about 2 hours if you take your time, and it works.
Good Luck :seeya
Old Feb 27, 2004 | 11:38 PM
dzierke's Avatar
dzierke
Default Re: Digital heat/ac question (chb88)
I don't mind cleaning the contacts if it will save some $$ Where is the control module located? Also, is there any hidden valves the control the direction of air to certain vents, ie the defroster, dash & floor vents? I would like to clean or lube these areas. :leaving:
Old Feb 27, 2004 | 11:50 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Default Re: Digital heat/ac question (dzierke)
You might want to check the programer
Old Feb 28, 2004 | 12:02 AM
dzierke's Avatar
dzierke
Default Re: Digital heat/ac question (Coupe89)
<You might want to check the programer>
Your talking greek to me. in english please?
:flag
Old Feb 28, 2004 | 12:44 AM
Coupe89's Avatar
Coupe89
The programmer controller controls the hot/cold and other function of the A/C head unit. Its located on the driver side up on the firewall inside the car(Need to be upside down to get to it)
One of the resistors worked it self losses on mine (common problem)
Check this site http://www.batee.com/corvette/acrepa...oard/c68.shtml
[Modified by Coupe89, 9:47 PM 2/27/2004]
To Digital heat/ac question
