knock sensor
Old Feb 28, 2004 | 05:58 PM
6spd's Avatar
6spd
Default knock sensor
i diconnected the wire to the knock sensor now i have 20 degrees of knock retard at 2000 rpms. i thought these can be diconnected???
Old Feb 28, 2004 | 06:44 PM
Pete K's Avatar
Pete K
Default Re: knock sensor (6spd)
I only disconnect my knock sensor @ the dragstrip. On my 87 it doesn't hurt anything. On my friends 92 f-body it throws a code 43 immediately and runs poorly. I plug my 87's back in before the ride home. I don't know what the car would do if left unplugged. Im sure someone will chime in and explain. :crazy:
Old Feb 28, 2004 | 06:49 PM
CFI-EFI's Avatar
CFI-EFI
Mine is disconnected. It has been for several years. Are you disconnecting the ESC when you're checking the base timing? How do you come up with:
...20 degrees of knock retard at 2000 rpms.
RACE ON!!!
Old Feb 28, 2004 | 07:31 PM
6spd's Avatar
6spd
Default Re: knock sensor (CFI-EFI)
i have the ez link scanner my car is a 91 vette i didn't disconect the battary i just pulled the wire out of the senser.
Old Feb 28, 2004 | 08:00 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I am not sure where the idea of just disconnecting came from. I had the wire fall off the sensor due to deteriorated plactic.
Threw an ESC FAILURE code and I frove home from Fla in Limp home mode.
If you are disconnecting because you are getting a lot of false knocks and therefore retard, try replacing the ESC with a NAPA ESC 209. They are les sensitive to noise.
:seeya
:steering:
Old Feb 28, 2004 | 08:03 PM
6spd's Avatar
6spd
Default Re: knock sensor (jackdaroofer)
i am getting false knock do to the headers hitting and vibration
Old Feb 28, 2004 | 08:19 PM
CFI-EFI's Avatar
CFI-EFI
Jack,
If you got a code, maybe it was because the loose wire grounded. A code will set if the if the ECM sees low voltage for too long. The knock sensor grounds that circuit when it detect knocks. If your connector was grounded for too long, that could have caused a code. Mine has been disconnected for years... No codes.
6spd,
When you check your base timing, you need to have the ESC wire disconnected. When you are through, you need to disrupt the power to the ECM, to clear codes.
RACE ON!!!
[Modified by CFI-EFI, 6:24 PM 2/28/2004]
Old Feb 28, 2004 | 08:21 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:cheers: The best solution seems to be to replace the ESC module with the ESC 209. Gorden Killebrew, the guru of C4's recommends that! The stock vette ESC module is too sensitive to false knocks, headers are a particular problem
The ESC module is a simple swap, it is screwed to th e heater housing on the passenger side
:seeya
:steering:
Old Feb 28, 2004 | 08:31 PM
CFI-EFI's Avatar
CFI-EFI
:seeya
:steering:
Jack,
Basically, I agree. In MY situation, I tested with 93 octane gasoline and base timing set at 0. I was getting knock counts, revving it in neutral. My long block is all stock, never disassembled. No headers, either. Now, I run 14* base timing on 85 octane gasoline. No knock... No counts.
RACE ON!!!
Old Feb 28, 2004 | 08:53 PM
6spd's Avatar
6spd
so just change the knock sensor to the 209 and get it at napa auot parts.
Old Feb 28, 2004 | 08:56 PM
6spd's Avatar
6spd
i have a 91 i have the knock senser that srews into the block thats what you mean???
Old Feb 28, 2004 | 08:57 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:cheers: No, you are not changing the knock sensor, you are changing the ESC module that interprets noise and sends it to the ECM!
If you oreder NAPA ESC 209, you will see the whole thing
:seeya
:steering:
Jack
Old Feb 28, 2004 | 09:05 PM
CFI-EFI's Avatar
CFI-EFI
Like Jack said, the module on the side of the blower motor housing, not the sensor, itself. Check the "Tech Tips" and maybe that will make it more clear.
RACE ON!!!
Old Feb 28, 2004 | 09:14 PM
6spd's Avatar
6spd
i checked napa did not show it?? also i didn't know 91's came with the module.
Old Feb 28, 2004 | 09:28 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:rolleyes: You are right! 91's were hard wired from the sensor to the ECM
Sorry for the bad info, and also sorry for lack of better info
:seeya
:steering:
Old Feb 28, 2004 | 09:33 PM
6spd's Avatar
6spd
thats okay, it happens do you think i should put so teflon tape around it to desenitize it?? or i can do what my friend did he bought a custom prom.
To knock sensor
