Fusable Link
Old Mar 3, 2004 | 09:26 AM
cmtatlanta's Avatar
cmtatlanta
Default Fusable Link
I messed up and had the Battery hooked up when I was replacing the alternator and blew the fusable link behind the battery. Has anybody had any experience with this? ie dealer item only? What size/amp is it?
Old Mar 3, 2004 | 09:53 AM
LD85's Avatar
LD85
Default Re: Fusable Link (cmtatlanta)
I cut mine out and put a Fuse connection that is removable in its place from Autozone. Autozone also has the fusible links
Old Mar 3, 2004 | 11:38 AM
cmtatlanta's Avatar
cmtatlanta
Thanks!! I'll splice one in over the weekend.
Old Mar 4, 2004 | 09:55 PM
HWoods's Avatar
HWoods
How can you tell what rating the fusible link has?
Old Mar 5, 2004 | 08:21 AM
LD85's Avatar
LD85
Default Re: Fusable Link (HWoods)
GM Manual
Old Mar 5, 2004 | 03:47 PM
GRX's Avatar
GRX
Fusible Links are nothing more than a piece of wire covered in an anti-flamable insulation; The gauge of wire (fusible link) is always less than the size of wire circuit that it is protecting. IF the circuit is comprised of 10 awg wire THEN the fusible link should be approx. 5-6 inches long and be of 14-16 AWG.
The rule of thumb is 4-6 AWGs smaller than circuit protected.
[Modified by GRX, 12:47 PM 3/5/2004]
Old Mar 7, 2004 | 02:17 PM
c4_4ya's Avatar
c4_4ya
I think the same thing happened to me yesterday while replacing the starter on my 85 - where is this fusable link exactly?
Old Mar 8, 2004 | 01:20 PM
cmtatlanta's Avatar
cmtatlanta
Remove the battery and it's right on the firewall.
Old Mar 8, 2004 | 04:23 PM
scorp508's Avatar
scorp508
The links say right on them 12GA for 12 gauge etc. I bought 20' of 12 gauge fusible link at NAPA last year for around $14 and just replaced it with the same length as the one I blew.
To Fusable Link
