PCMFORLESS ??
Old Mar 14, 2004 | 10:25 AM
  #41
larryfs's Avatar
larryfs
Default Re: PCMFORLESS ??
I have a question about the 96 fan temps.
the 96's have a low - high speed fan setup where both fans run either at low speed or high speed.
low speed 219on - 207off
high speed 228on - 214off
I changed thermostats to 160, so I need to adjust the fan temps accordingly.
what would you recommmend?
I was thinking about lowering each number by 20 degrees. this way the temp spreads are keep the same .... but a little :confused:
the car is otherwise stock, but I do road race it, and I want the temps cooler in the pits.
[Modified by larryfs, 10:29 AM 3/14/2004]
Old Mar 14, 2004 | 12:55 PM
  #42
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Re: PCMFORLESS ?? (larryfs)
For reference purposes ONLY, my Hypertech PPIII manual states that the stock fan temps for the 1996 LT1/LT4 are 240/225, optimized for a 180 t-stat are 213/205 and optimized for 160 t-stat are 192/185. That's not advice or a recommendation, just info from them that I'm just passing on...
[Modified by tobijohn, 12:56 PM 3/14/2004]
Old Mar 14, 2004 | 02:43 PM
  #43
larryfs's Avatar
larryfs
Default Re: PCMFORLESS ?? (tobijohn)
good reason not to buy a hypertech!
my information comes from the 1996 GM service manual, page 639
Old Mar 14, 2004 | 02:50 PM
  #44
red95vette's Avatar
red95vette
My tranny line pressure was increased with my tune. Just curious if this decreases the tranny's life, because I've heard from several people it did? Thanks.
Old Mar 14, 2004 | 02:58 PM
  #45
tobijohn's Avatar
tobijohn
Bench Racer
Yup, they were wrong about the GM stock fan temp settings but if you use the Hypertech PPIII to reprogram your fan settings, the two I mentioned are your only options...
Old Mar 14, 2004 | 03:15 PM
  #46
larryfs's Avatar
larryfs
does that hypertech keep the 2 speed fan setup, or just does 1 speed at those temps?
Old Mar 14, 2004 | 03:21 PM
  #47
Lone Ranger's Avatar
Lone Ranger
If you look at PCMFORLESS's web page, one service they offer is OBDII to OBDI conversion, makes your OBDII '96 such that it can be programmed via an OBDI tuning application like Tunercat. Then, you have ultimate flexibility to go in and set your fans to whatever temp you want, add a degree or few of spark advance anywhere in the rpm band, alter Power Enrichment fuel tables, etc. If you have access to a shop with a dyno and that has a wide band oxygen sensor you could get your air/fuel curve well optimized if you spent some time and pulls... took your laptop and cable to the dyno shop with you.
Also, I believe that once you do the OBDII-to-OBDI conversion, if you have your own cable and laptop you can then get PCMFORLESS's tuning for $50 a pop emailed to you to upload with your cable and laptop yourself.
If I had a '96, I would definitely consider the conversion to OBDI... just to get the car setup to where I could make changes to the programming myself. But that's me. I think the only major change with the conversion to OBDI is that the PCM ignores input from the crank position sensor, which is an OBDII-specific sensor not installed on OBDI cars. There's a FAQ about it on their site.
[Modified by Lone Ranger, 2:22 PM 3/14/2004]
Old Mar 14, 2004 | 03:23 PM
  #48
tobijohn's Avatar
tobijohn
Bench Racer
Good question. I sent you an IM...
Old Mar 14, 2004 | 03:28 PM
  #49
Lone Ranger
I used to have an HPP+ for my '95. It maintained the 2 speed setup-- both fans always ran together, at a low speed that you couldn't hear and at a high speed that had a bit of noise to it, same way as stock. I'm fairly certain the fans are wired in series such that they cannot operate independently of each other in '94 - '96 models, maybe even previous LT1 years as well (?). There is some confusion because in the PCM there are references to FAN1 and FAN2 but this refers to low speed (FAN1 setting) and high speed (FAN2 setting), not the fans being activated independently/individually.
[Modified by Lone Ranger, 2:29 PM 3/14/2004]
