Ok, the other day after installing the new injectors (slp 25lb.) I went ahead and replaced my spark plug wires, (which needed to be replaced anyway) started the car up, and after a few times and it ran. It was idling at about 1200 but it ran and sounded fine . So I let it run for awhile and then decided to test drive it. I did, but it was running way rich and died a couple of times when at lower rpm's and when going from park to drive. Later on I checked for a code and got '45', looked it up and found out that it was high 02 sensor voltage. I replaced my 02 sensor when I installed my air/fuel ratio gauge in january. Then yesterday I checked my fuel pressure on my adjustable fuel pressure regulator and it was about 38-41psi. I can't turn it down anymore because the screw hits the bottom of the plenum. Also, I got it to start but it sounded like crap and would'nt stay idling by itself, but then I took out the F.P. fuse and started it up and it ran and idled by itself for about 30-45 seconds then died. I did check for a code afterwards and it was '33', and my car is an '88 if i can remember correctly that indicates a bad MAF sensor for my year, right?
Is it possible that my fuel pump is pumping too much fuel?
Could a bad MAF make my car run this way?
Anyone got any ideas?
I wish I could find the problem here, It's been broken for a total of 2 months now, and it seems like nothing is working! :mad
Things recently replaced:
- Coil, Cap, Rotor, Spark Plugs, Spark Plug Wires, Fuel Injectors, Fuel Filter, Fuel Regulator, 02 Sensor, Not to mention the brake booster and alternator.
Re: Still got problems...Help needed! (-=Persephone=-)
Take a screwdriver with the engine running and give a few whachs on the maf housing. If the engine rund better or worse(usually stalls) this will show a bad sensor. This hillbilly test will not prove it good only bad. You may need a new relay. Switch the maf with the maf burn off relay. If code changes to 34 it is the relay. Also check fuel pressure to be sure it is right.
I am hoping for you wallets sake that if your code33 is a relay that is a 7 dollar fix. My car needs new relays every 3 years or so.It is real easy to switch the maf with the burn off relay that takes 1 minute. That is why I sent you there first. Many people run out and buy a $200 maf sensor only to foind uot it was in fact the relay. keep us posted.
