Another TPS Adjustment Question
I have my voltmeter set at 20K and the TPS reading at idle displays "2.56" rather consistently.
Should I adjust my TPS until the gauge reads ".56", not "2.56"? Or is my current reading ideal?
Aim for arround .58Volt (not 2.56) with the throttle closed, and then have someone hold down the gas pedal or the throttle body linkage to the Wide Open Position (with the key in the "On" position and the engine off of course). At the open position, you should be at 4 volts or higher, and when you release it, arround .58 volts or so. You might have to play with it till you get it right. Keep us posted.
[Modified by 86PACER, 3:41 PM 3/20/2004]
