Another TPS Adjustment Question
1. Do I still have to ground out the A & B terminals to the ALDL before adjusting the TPS?
2. I'm going to try paper clips in the harness to gauge the voltage. Can I just place these in there when the car is turned off? Once I turn the ignition to the "ON" position I'm guessing I shouldn't touch the paper clips with my hands? Don't want to get ZAPPED!!
3. To actually adjust the voltage, I know that I have to loosen the two torx screws. Will simply loosening the screws "adjust the TPS" or will this simply allow me to move the entire plastic harness around until I find the voltage that I'm looking for (.065v)?
I've read through the tech articles but I guess I'm just trying to leave myself no room for error (either with the car, or myself....ZAP!!)
Thanks,
Jon
Man electrocuted by 2 amps of 12 volt power!
1.) No.
2.) Nothing to worry about. You won't feel a thing. I exagerated. It isn't anywhere near 2 amps, and the spec is for less than 0.6 volts. If it makes you feel better, play it safe, but you are at no risk. Simply ignition on, engine off. Start by just barely loosening the TPS screws. It is better if it takes a little effort to move the sensor. That way it will move less when you snug it up.
3.) See above. Don't loosen the screws too much. You have to rotate the TPS in the slots provided, to adjust the volt reading.
It is a piece of cake. Once you've finished, you'll wonder why you asked. You have nothing to fear but fear, itself. Good luck, and...
RACE ON!!!
[Modified by CFI-EFI, 4:55 PM 3/19/2004]
Then unplug the IAC connector, remove the ALDL jumpers, start the engine and set base idle to about 450RPM.
Shut the engine off, loosen the TPS screws slightly, probe the ground & signal wires with a DMM and rotate the TPS about the top screw till you get a reading of around .65Vdc (over .67Vdc may trigger a TPS code). Then open the throttle fully and tweak the TPS position for max WOT voltage. Recheck that the base idle voltage is still .65Vdc and tighten the two screws.
You can use a TPS diagnostic harness or simply jumper the pins in the connector to those in the harness.
What about disconnecting the EST connector?
The tech tip left this out and the GM Shop Manual says to do it.
What is your take on this?
[Modified by 86PACER, 4:36 PM 3/19/2004]
SAM
Though I didn't do the timing nor the EST, these are good ideas. However, I did adjust base timing after doing the TPS tweak.
CFI-EFI: thanks for the high voltage warning...J/K. I'm new to the whole "work on the car" thing, and you have now single-handedly eliminated my fear of getting ZAPPED!! Thanks, Jon
I'm getting ready to set the base idle. I understand that this is the small round hole at the top of the throttle body on the driver's side. Mine appears to be sealed with a thin piece of metal. Is it cool to pierce this with a screwdriver?
[Modified by 86PACER, 6:01 PM 3/19/2004]
[Modified by 86PACER, 11:50 PM 3/19/2004]
The base idle is set...no problems. Here's what I did next and I'm running into problems:
With the key off, I inserted pins in the top (black) and middle (blue) wire on the TPS harness. Seem to have a good connection. Next, I turned the ignition on (engine off) and went to test the voltage at idle. I'm touching the positive lead (red) to the top wire and the negative lead (black) to the middle wire, but I cant get a consistent reading. The numbers are all negative and jump around wildly.
This is my first time with a digital voltmeter. Here's how I have it setup:
I'm turning my dial to 200m under the DCV setting. (I've also tried the 2000m DCV setting) The red tester is plugged into the 1000VDC / 200mA MAX plug and the Black tester is plugged into the COM 500V Max plug.
Anyone have suggestions as to what I could be doing wrong? Or is this a time where the "shouldn't have bought the $20 voltmeter" saying comes into play?
SAM
My e-mail address: jbrinson7@aol.com
Thanks for everyone's assistance (and their patience) while I'm trying to learn.
Jon
And when it's all set and done, remember to disconnect your battery for about 5 minutes to clear that code 42 you threw when you unplugged the EST and started the engine.
[Modified by 86PACER, 3:38 PM 3/20/2004]
I have my voltmeter set at 20K and the TPS reading at idle displays "2.56" rather consistently.
Should I adjust my TPS until the gauge reads ".56", not "2.56"? Or is my current reading ideal?
Thanks for your help everyone. Right now I feel like a dog that JUST learned to roll over!!
SAM
