Yesterday I took down valve covers and started with installing valve seals to exhaust guides. When I took down rocker I saw that rocker was hitting
the retainer. I took down all of the rockers and the situation looks the same.
I have installed wider springs with cam ( 1.470" ). But I think that
problem is here because machining guy machined top of the valves.
Do you think that roller rockers could solve the problem?
I think my cranes will clear 1.5 springs.
Check rocker manufacturers websites to see what's the largest spring diam. that can be used.
:cheers:
I checked, and it is a maximum diam. of 1.5" with my crane energizers.
They recommend a minimum of .040 clearance beteween spring and rocker
:cheers:
That's why I went with my 1.7 rockers. My crane golds hit the huge springs that are on my heads. I knew the Scorpion rockers had plenty of clearance, I thought I'd give the 1.7's a try since I had to replace them anyway.
