Roller rockers
Old Mar 28, 2004 | 09:44 AM
Sliding's Avatar
Sliding
Default Roller rockers
From what I've seen arround here it look like CC's Pro Magnums
( non self-aligning ) are the most used and best choice.
Can somebody please help me with part numbers at summit racing?
I know that I need also pushrods and guide plates and I would also like
to get 7/16 studs.
At summit page there are several possibilities and I would like to
get the right stuff that I need for my '90 L-98.
Thank you!
Old Mar 28, 2004 | 10:30 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Roller rockers (Sliding)
Here's what I put in my '88 L98 with #113 heads:
ARP-134-7103, ARP 7/16" rocker arm studs, $25.05
CCA-4800-8, Comp Cams guide plates, $24.25
CCA-7608-16, Comp Cams Magnum push rods, $93.02
CCA-1305-16, Comp Cams 1.6:1 ProMagnum RRs (7/15"studs), $260
CCA-102, Comp Cams engine assembly lube, 4oz jar, $5.52
Pricing is from 04/21/2991.
I suggest you also e-mail Comp Cams and see if they will ship to you at a price comparable to Summit.
BTW, Comp Cams uses the above p/n but without the CCA prefix.
[Modified by 65Z01, 10:38 AM 3/28/2004]
Old Mar 28, 2004 | 10:54 AM
Sliding's Avatar
Sliding
Default Re: Roller rockers (65Z01)
Thank you very much.
Old Mar 29, 2004 | 12:14 PM
Sliding's Avatar
Sliding
I've checked on summit page and ARP studs that you gave me
are shorter than stock ones. Is this because RR's are different
and this studs will be good for them.
What heads do you have? I have #113 D-ports.
Also, pushrods are thicker than stock ones.
Will their ball ends fit stock lifters?
Thanks.
Old Mar 29, 2004 | 12:23 PM
mos90's Avatar
mos90
i just did this converstion on my 91 but i used 3/8 rockers because i had them. but most is the same except for studs.
cca- 4808-8 guide plates
cca-7808-16 high energy push rods they are hardened and only 36.00
arp-134-7104 3/8 studs. 1.895" length for rr's
the push rods are 5/16" for all apps.
these studs are a little longer that stock for rr's.
pushrods will work with stock lifters.
the studs that he recommended are 1.770" length not sure what length is best.
[Modified by mos90, 5:40 PM 3/29/2004]
Old Mar 29, 2004 | 12:43 PM
Sliding's Avatar
Sliding
Default Re: Roller rockers (mos90)
I measured my stock stud and it's 2.250" long.
Maybe they are measuring only upper part ???
On summit page it says 1.770" overall length.
Old Mar 29, 2004 | 12:52 PM
mos90's Avatar
mos90
length is measured for the bottom of the base to the top. dont measure the part the screws into the head.
Old Mar 29, 2004 | 01:05 PM
Sliding's Avatar
Sliding
Thank you! :chevy
To Roller rockers
