Clean the Plenum
Mar 30, 2004 | 10:30 PM
Clean the Plenum
What/how does everyone clean their plenums, I want to clean mine before I put it back on the car and the inside is pretty dirty and the small passages have some carbon inside, I was thinking about having a machine shop put it in the hot tank, is this a good idea or will it ruin or warp the plenum ?
Thanks.
Mar 30, 2004 | 10:41 PM
Re: Clean the Plenum (jeepie91)
As long as the plenum is off the car 2+2 carb cleaner works great. leaves the plenum with a new look
Mar 30, 2004 | 10:46 PM
Machine shops have a cold tank for aluminum and similar :thumbs:
Cleaner in a can works good. I used a bottle brush on my runners.
:cheers:
Mar 30, 2004 | 10:49 PM
Took mine down to TPIS to have them hot-tank it, ... turned out good as new. :)
Mar 31, 2004 | 12:06 AM
I used brake cleaner. It took the carbon off vaery easily :yesnod:
Mar 31, 2004 | 12:13 AM
Re: Clean the Plenum (TA)
:iagree: Quick and cheap method.
Mar 31, 2004 | 12:23 AM
Re: Clean the Plenum (rsafier)
:iagree: :iagree: I also used that method.
Mar 31, 2004 | 01:17 PM
Thanks, I will give the brake cleaner a try.
Mar 31, 2004 | 07:45 PM
Re: Clean the Plenum (AGENT 86)
:cheers:
:iagree: Bottle brush worked like a charm :cheers:
