Another "Is This Normal" Question...
Old Apr 6, 2004 | 10:44 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Default Another "Is This Normal" Question...
I start up the engine on my 1985 and the AC compressor cycles on and off about every 5 to 10 seconds. Is this normal? I just don't know...
:confused:
Here's the state, as far as I can describe:
Engine idling at about 900 rpm
Defogger on
Ambient temperature about 45 to 50 degrees
Old Apr 6, 2004 | 10:49 PM
BillWelter's Avatar
BillWelter
Default Re: Another "Is This Normal" Question... (j3studio)
Sounds normal to me - when the defroster is on, the AC kicks on too to get the humidity out of the air and defog.
Old Apr 6, 2004 | 10:53 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Default Re: Another "Is This Normal" Question... (BillWelter)
Thanks, Bill. If I were a better troubleshooter I would have seen if it does it with the HVAC off.
:seeya
Old Apr 7, 2004 | 07:55 AM
vetteseniorcit's Avatar
vetteseniorcit
Compressor cycling as you describe is almost always due to low Freon. Have your A/C checked at an A/C service. Freon is a bit on the expensive side, like $40 per lb., perhaps more depending on location.
To Another "Is This Normal" Question...
