Thanks to all the fine people on this forum that have been so helpful to me. I do appreciate it! :thumbs:
Last question (well, maybe not), is it a good idea to install a throttle body "air foil", and if so, which one? I have a 1996 LT1 Coupe. I see that there is a bolt-in style and a snap-in style that is held in by the air inlet hose.
My car had one when I bought it, it actually slipped into the intake duct. Another friend's 92 had the EXACT same thing, almost as if it was there from the factory. I left it in there because if for nothing else it helped hold the duct open and made it easier to put it back on the TB.
With my Holley throttle body (useless BTW) I can't use the air foil so I took it out. It's certainly not worth spending any money on.
Hi.
To understand why the airfoil should help you have to look at the whole air induction chain from the air filter to the heads. The air foil makes less turbulens in the intake and to have hp and torque gains that place of the throttlebody without airfoil must be the place of air obstruction. If you then put in an airfoil the throttlebody manage to flow more air and you will gain some power . If you change to a larger throttlebody you most prbably will gain more.
What they say about gains are true,but there is this "but". The throttlebody has to be the weakest point of the air induction chain to get the full gain.
You will most probably gain something in throttleresponse in a stock car. I thought the 96 had a quite good air induction system. The price for it is high.
The snap on type can during time be misplaced so if you buy one have the bolt on type. Anyhow you will not get the seat of the pants feeling, but making the airflow somewhat better.
I have one myself.
Buy a air foil that bolts in place like the TPIS air foil. A few years ago GM high performance did a test on a 1994 Z-28 Camaro that was all stock. in stock form the car put down 240 ish RWHP with the addition of the air foil the car picked up 7 RWHP at higher RPM. It may be hard if not impossible to feels 7 RWHP when it builds gradually as the RPM rise but never the less the air foil did work well. Seven RWHP for 50 dollars is a bargan.
.... A few years ago GM high performance did a test on a 1994 Z-28 Camaro that was all stock. in stock form the car put down 240 ish RWHP with the addition of the air foil the car picked up 7 RWHP at higher RPM. It may be hard if not impossible to feels 7 RWHP when it builds gradually as the RPM rise but never the less the air foil did work well. Seven RWHP for 50 dollars is a bargan.
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Re: Throttle Body Air Foil (bjankuski)
[Modified by bjankuski, 9:48 PM 4/11/2004]
I thought about a 150Shot of Nitrous but then decided on my Airfoil. :yesnod: I saved money and picked up plenty of RWHP! :party:
:jester
Yeah, what's really funny is that common sense says it should work...until you look at the two barn-doors right behind the TB openings in the plenum. Those were the first things I ground away. I still left the airfoil off when I put the 52mm TB on though.
I'm only a novice, but I know that more air in, and more air out means more hp. I never could determine how an airfoil adds more air, so I figured it's not for me.
