? for Canton Road Race Pan Users
After the fact I found a good description of how this happens in my 5th edition GM "Chevy Power Manual" page 3-29 directly from the manual....
"The final most difficult basic requirement is a steady oil pressure supply. The majority of engine bearing failures are a direct result of oil pressure loss due to the oil pump picking up air while negotiating turns at racing speeds. This occurs at a time when the driver is busiest and may go unreported, or be reported as a slight drop in oil pressure in the turns.
Oil pressure loss in turns is aggravated by three things:
1) Insufficient oil level or capacity
2) High engine oil flow rates due to excessive bearing clearances, or higher than necessary oil pressure.
3) Improper oil pan baffling, usually over-baffling which prevents the engine oil from properly draining back into the oil pan while the car is in a turn."
I had planned to install an oil accumulator but didn’t get it completed in time for the event, believe #3 above was part of the cause; the sustained RPM over such a long period allowed the HV pump to fill the upper end W/ oil and the extra baffling in the Canton RR pan slowed the oil return rate to the sump. During one of the long 120 MPH + sweepers the G loading caused the oil in the sump to move away from the pickup for a split second.
My bad should have had an accumulator installed, knew better...
keep in mind, the bypass means you don't see more than 70psi, ever. so if there's no increased pressure, just how is all the extra oil going to the top of the engine? and why does a HV only fill the top without more flow also going past the crank/rods and back into the pan.
also, your excerpt doesn't say a HV pump will suck a pan dry.
i don't deny some problems exist with certain combinations, but the sucking dry theory just doesn't fly with me. for one, i overfilled mine by 2 quarts and it behaves identically. no lag in the pressure drop at all. it's purely a function of rpm. i can sit still in the driveway and keep it at 4900rpm for hours, but as soon as i go past 5k rpm, the pressure drops 20psi.
i am sorry to hear of what happened. is it back together now? if so, what pump/pickup/pan combination are you running?
-michael
I agree, it did not suck the "pan dry" but IMHO it puts too much oil into the top end.
The gold nugget of Info was #3 in that list for me. The extra baffling is great for keeping oil at the sump provided there is enough oil in the sump to begin with. After that the baffling slows the oil return to the sump.
I believe my sump got low enough during the sustained RPM W/ slower than normal oil return. G forces placed the remainder of oil in the sump away from the pickup for a split second. The car was fine & still made plenty of power for months afterwards. Found the issue on tear down / inspection.
FWIW, I ran Mobil-1 15-50 and had the rod & main bearing clearance set at .0023 -.0025
Just a theory Mike, I'll address the balance of your question later...
-Jim
it also appears the cover is different, such that the bolt-on tab for the pickup might not work. since i could not get the pickup in place, i can't be sure on that, though.
if you guys figure it out, let me know. i bought my 10552 when they very first came out, it could be that melling has changed them since then.
-michael
I just spoke to Dan at Melling and he said that you can use the same pickup for the M155HV (20-079) as you can for the 10552. He told me the 10552 looks different but you can press on, or bolt on using a flanged bolt. he said the measurements are .739 at the start and .735 at the press, which he thinks is 19mm.
We'll see if John can get it together this weekend.
Mike
maybe it would have gone in if i forced the issue. on the other hand, the pickup went it with just some tapping into the 155 pump.
i still have the parts, i'll check them out when i get time. or update us on what john finds.
thanks.
ralph, thanks for the info. i always check for that, fwiw.
-michael
-michael
Last winter I went thru an exercise on installing a 4 stage dry sump system, believe I have it figured out but spring is here and that will have to wait until next winter. I plan to reuse this Canton pan or possibly sell it and purchase one of Merle's new pans out at Exotic Muscle, probably toss the Canton HV pump and get a standard volume pump & blueprint it W/ cavitation grooves Etc. My only concern is low oil pressure with the added oil cooler / filter and large -10 plumbing. And the car won't even be fired up until a 3 QT oil accumulator is in place.
Here is a shot of the pump; I wasn't using the oil filter adaptor in the pic. I had a large block off that went to a remote unit
[Modified by superlund, 6:45 PM 4/14/2004]
the baffles preventing quick return is an idea i had as well. part of the reason this occurred to me is because my oil level sending unit often claims the oil level is low, when i know it's not. i replaced the sending unit, no change. so something funky is going on.
were you using the sending unit for oil level? if so, did it work properly?
who is peterson fluid systems?
thanks.
-michael
Mike
You should use both the manual and electric valves. (The manual is a back up in case the electric valve pukes, which I understand is not uncommon.) Just make sure that you place the mounting band clamps at the outermost ends of the sump. (on the endcaps is good.)
Since it's a closed system, it has to be stacked someplace.. :confused:
heads?
under the intake?
I've heard of oil stacking in the heads on some high camber road courses.
Have you guys tried "porting" the oil returns? polishing etc.
How about running extra return lines from the valve covers?
in my engine it's not in the heads. i can leave the oil cap off and not see an appreciable puddling of oil in the head at any rpm. all of the lifters seemed to have tight tolerances into the lifter bores, so i don't think oil is puddling under the intake.
if there were debris in the oil drainback holes from the lifter valley, that would be a problem. (but it would also be a problem with a SV pump.)
something else, if flow is increased through the rods (and i maintain there's no flow increase unless you're seeing higher oil pressure), there's more potential for windage to mist the oil. now this is something i might be experiencing, since oil does pool into the hose connecting crankcase and TB. my engine does not consume oil, nor does it have blowby, so such an accumulation is likely due to condensing mist.
if i'm having this problem, it would have to be due to the rod clearances and rod side clearances being too large, since i'm never seeing higher than stock oil pressures.
there's a lot going on here. but that's always the case when something is really analyzed closely. i've always been a proponent of SV pumps, but for different reasons. these problems just solidify my initial stance.
-michael
thanks.
-michael
Here's a couple links.... http://www.petersonfluidsys.com/index.html http://www.rehermorrison.com/techTalk/36.htm
Brian C,
Yes I ported the oil return passages to a degree, when I initially built the engine I worked on the oil return passages in the heads with a die grinder. In reality the LT4 heads have very large rectangular shaped oil returns at each end, much better / larger than the old "round" 3/8" - 1/2" SBC oil returns.
I've got to admit; when I was diagnosing my problem I found a post where H Rocks described the problem almost exactly. I believe it was in the Auto-X Road Race section, he spoke of how his oil light would illuminate for a split second at high G load cornering. I think the large light is key as most of us are way to busy at speed in high g cornering to ever notice the drop on a gauge...
-Jim
[Modified by superlund, 7:17 PM 4/15/2004]
thanks.
-michael
1. Open up the inlet tube on the pump by .0015 (I think that is right)
2. Put a notch in the pump so the bolt flange on the pickup could slide in.
3. Increase the size of the bolt hole (horizontally) on the pickup so it would line up with the pump hole.
Here is a shot of Jim's motor with the 20-079 pickup and what I believe to be the M155HV pump:
This will give you a better idea of what John had to do to mate them up. We were also lucky there was a kid working on a tube frame chasis car at the engine lab who tack-welded it for us.
Next comes the notch for the sensor on the passenger side of the pan, and checking the dipstick. We now have the bottom end together (no clearance issues) but are waiting on a new timing set and rear main seal from Superior Chevy.
BTW, Nathan, sorry about us somewhat hi-jacking your thread. I do think there is some pretty good information here though if anybody plans on going with this Pan.
Mike
[Modified by luvmy92, 11:28 AM 4/18/2004]
Mike
[Modified by luvmy92, 9:19 AM 4/18/2004]
how did john open the pump inlet?
i think i'm probably going to try a stock pump next.
-michael
Anyway, the OD of the pickup tube is 0.749", and the ID of the pump housing is 0.735". I took a 0.750" 4 flute end mill, turned it down to a 0.745" diameter, and built a small jig so that I could clamp the bottom piece of the pump housing in a mill. I literally just plunged the end mill into the hole once I centered the spindle on the hole's centerline. I will be up at the engine shop for a few minutes tomorrow, and will try to take some pictures of the notch I made in the pump housing and the mods I made to the pickup's flange to make it fit.
:confused:
