Holly AFPR Owners, does it clear your plenum?
Apr 19, 2004 | 06:40 PM
I've recently installed the Holley AFPR on my L98, and when reinstalling the plenum noticed that it rests against the underside of the plenum.
Anyone else have this issue?
Should I go at it with a dremel?
Apr 19, 2004 | 08:49 PM
Cruise-In V Veteran
Re: Holly AFPR Owners, does it clear your plenum? (FlyboyZR1)
On my original setup , I had a similar problem that a dremmel took care of.
You have to have some leeway to adjust the pressure.
Apr 19, 2004 | 08:53 PM
No problems here on my 86.
Apr 20, 2004 | 09:31 AM
Didn't have to dremel, but it is a tight fit.
Apr 20, 2004 | 09:32 AM
Re: Holly AFPR Owners, does it clear your plenum? (HeeHaw89)
I needed to grind the plenum a little bit on my 86.
Apr 20, 2004 | 10:22 AM
No problem on my 89.
Apr 20, 2004 | 12:52 PM
Re: Holly AFPR Owners, does it clear your plenum? (GKK)
Fit fine on my '89, using AS&M runners though, never tried with stock ones.
Apr 20, 2004 | 03:47 PM
Mine hit the plenum, but it was nothing a little grinding with the dremel couldn't take care of. I took a fair amount of material off, just be carefull you don't go through.
Apr 21, 2004 | 12:25 AM
Same here- no probs. :)
Apr 21, 2004 | 01:22 AM
No problems with clearance.
I set my pressure with the plenum off. Have you adjusted it to the proper psi, maybe it will sit lower.
:cheers:
