Accel injectors ??
Old Apr 19, 2004 | 09:38 PM
LSC SS's Avatar
LSC SS
Default Accel injectors ??
Everything I have read online including various online catalogs lists the Accel 150124 injector as being the one for a 89 TPI motor. Just bought a set and they are too short. Anyone have a clue why?? (Other than the obvious, i bought the wrong ones apparantly)
Here is the measurement on the accels:
The stock ones measure 2.6875
[Modified by LSC SS, 9:46 PM 4/19/2004]
Old Apr 20, 2004 | 06:50 AM
kman0066's Avatar
kman0066
Default Re: Accel injectors ?? (LSC SS)
I don't know the specifics here, but most aftermarket injectors don't fit exactly the same. Have you tried installing them? They might still work, they just won't protrude so much.
Old Apr 20, 2004 | 07:05 AM
No Go's Avatar
No Go
I have the 36 #'s in my LT4...they are shorter, but still seal fine.
Try it...you will like it. :)
Old Apr 20, 2004 | 08:27 AM
jmrl98's Avatar
jmrl98
I have the accel 24# that I bought from Jeg's. They fit my 85 no problem, with 1 year and 3K on them so far and no problems. :seeya Try to put them on, they may fit .
Old Apr 20, 2004 | 03:08 PM
1MoorTym's Avatar
1MoorTym
Default Re: Accel injectors ?? (No Go)
:iagree: They don't go as deep into the manifold, but they work fine.
Old Apr 20, 2004 | 05:44 PM
LSC SS's Avatar
LSC SS
Default Re: Accel injectors ?? (1MoorTym)
Did you guys use the locks that came on the stock injectors to lock them into the fuel rail?? When I did that it seems too short and when I put them in without the lock I was afraid of it moving around and leaking. Guess this needs a second look. Thanx everyone !!
Old Apr 20, 2004 | 05:58 PM
corvette1990's Avatar
corvette1990
I have the 24s Accel in my 1990 as well. I have new locks too as the old ones were britttle, they seal top and bottom with the orings. The lock into the fuel rail. Yes they are a little shorter work well for me. Despite several on the forum swearing they have had problems with them. 3 years and no problems with them. :flag
Old Apr 20, 2004 | 06:11 PM
1MoorTym's Avatar
1MoorTym
:yesnod: Make sure you do too !! I've had mine several years nows and they are fine. I know its a little disturbing that they are shorter, but once locked in the rail the depth in the manifold is ok.
Old Apr 20, 2004 | 06:19 PM
LSC SS's Avatar
LSC SS
This may be a stupid question but are the locks available from GM ??
Old Apr 20, 2004 | 06:27 PM
1MoorTym's Avatar
1MoorTym
Yes they are, or at least were when I bought them. Let me know if you need a part number :cheers:
Old Apr 20, 2004 | 11:33 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You should use the locks to make sure they're seated in the fuel rail.
If you could choose between a slight vacuum leak, and a slight fuel leak, which would you choose? Actually, I think when the locks are used, it doesn't let the injector bottom out all the way up in the fuel rail, so it'll help your cause.
Old Apr 21, 2004 | 12:24 AM
C4Fanatic's Avatar
C4Fanatic
Default Re: Accel injectors ?? (CentralCoaster)
I just installed a set of LT-1 injectors in my '87 and I had the same worry. The LT-1's are a lot shorter than the stock L98, but so far so good.
Now if I could get the cold start injector tube to quit leaking behind the drivers side fuel rail.............. :mad
Old Apr 21, 2004 | 12:01 PM
LSC SS's Avatar
LSC SS
I just called the local chevy dealer and they tell me the lock tabs are $9 each, seems a little high to me !! :eek: A part # would be great, maybe I can search around for a better price.
Old Apr 21, 2004 | 03:58 PM
pablocruise's Avatar
pablocruise
I used Accels on my 89 TPI too. I also was stumped about their fitment at first, but they did go in fine. I found the injector clips at NAPA.
Old Apr 21, 2004 | 06:59 PM
1MoorTym's Avatar
1MoorTym
The clips come as a package and not individually.
Here's the delco p/n 17111267.
[Modified by 1MoorTym, 7:00 PM 4/21/2004]
Old Apr 21, 2004 | 08:15 PM
LSC SS's Avatar
LSC SS
:cheers:
Old Apr 21, 2004 | 10:21 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
how much is a set of injectors and is it ok to go to 30# injectors? My injectors are stock and I am rebuilding the engine. They had 127,000 miles on them, so should I get new ones and what injectors are suggested?
To Accel injectors ??
Old Apr 27, 2004 | 05:27 PM
LSC SS's Avatar
LSC SS
Went to the dealer today and he's telling me thats the wrong part #, thats exactly what came out of the car but his computer parts listing shows part # 17111800 as the one for the 89 http://198.208.187.182/servlet/com.e...rtnbr=17111800
Maybe it's an upgrade or something?? :confused:
[Modified by LSC SS, 5:29 PM 4/27/2004]
Old Apr 28, 2004 | 10:31 AM
jmrl98's Avatar
jmrl98
I have an 85, and I don't think those would fit. They aren't even close to the same shape as my locks. Weren't your stock locks semi-circular? I don't see how those would work. I used my old locks with no problems. :seeya
Old Apr 28, 2004 | 05:19 PM
LSC SS's Avatar
LSC SS
Default Re: Accel injectors ?? (jmrl98)
Went back to GM and got the right ones today, the guy still agrued with me that the original part he sold me was right and these here are wrong, go figure !!
I want to thank everyone for their patience and help !!
[Modified by LSC SS, 10:57 AM 5/2/2004]
