Spark retard
Old Apr 21, 2004 | 03:12 PM
corvette90's Avatar
corvette90
Default Spark retard
hi
i burned a matching chip for my engine, but i get spark retard under certain conditions...eg when hitting the gas...
i also ´hooked up datamaster on a stock engine, and it also shows the retard under the same certain conditions..the amount im dealing with are about max 5°
can i assume this is normal?
i dont hear knocking or pinging....
thanks
Old Apr 22, 2004 | 10:01 AM
Aaron's 87's Avatar
Aaron's 87
Default Re: Spark retard (corvette90)
You can't always hear it. It could be real and could be damaging your engine. It could be caused by too much timing, not enough fuel, carbon build up, no EGR, or a myriad of other things. Check your plugs after knock to see if there a little black/silver flecks of aluminum on them.
Or, it could be false knock.
I wouldn't consider it normal, try to figure out if you're really knocking and then get rid of the knock so you don't damage anything.
Old Apr 22, 2004 | 01:58 PM
Sliding's Avatar
Sliding
Default Re: Spark retard (Aaron's 87)
What do you mean by no EGR?
Old Apr 22, 2004 | 03:32 PM
corvette90's Avatar
corvette90
Default Re: Spark retard (Sliding)
in the shop manual, it is also said, that the ecm sometimes advance timing until it hears a knock..this is done, to prove the knock sensor
also a forum member stated, it is normal that the ecm advances spark to the max amount to get max power..and then reduces..
any opinions
Old Apr 22, 2004 | 05:05 PM
Aaron's 87's Avatar
Aaron's 87
I've heard that, but never seen it happen. Anyway, it wouldn't keep inducing knock. EGR is exhaust gas recirculation, an emissions function that also cools combustion temps.
Old Apr 25, 2004 | 04:04 AM
corvette90's Avatar
corvette90
ok..thank you for your answers..but, what to do now..
should i retard the timing at the point where knock occur, or...
my concern is, that i retard timing so far, that no knock will occur, but also no power ( or less)
i also doubt, that i can get completely rid of the knock counts....
any opinions
thank you
Old Apr 26, 2004 | 03:02 PM
Aaron's 87's Avatar
Aaron's 87
Yes, pull out timing where knock occurs AND before knock occurs. When you're more comfortable tuning, you can also change how much timing can be taken out, how fast it's taken out, and how fast it comes back.
My enginge doesn't knock unless carbon has built up. The knock sensor doesn't hear it, I don't hear it, and the plug don't show it. You CAN tune it out if your engine is in good working order.
Generally, you have at least a couple degrees of advance between peak power and knocking, but every engine is different. The only way to know is through testing. I guess you could use ion sensing, but that's too far in the future for our ECMs.
Old Apr 26, 2004 | 04:40 PM
corvette90's Avatar
corvette90
hi
that was exactly what i want to know
i assume engine is good, since it was rebuilt a time ago
thanks
To Spark retard
