Code 36 at 70 MPH
Old Apr 22, 2004 | 04:31 PM
JScott 88 C4's Avatar
JScott 88 C4
Default Code 36 at 70 MPH
Replaced the MAF sensor and the burn off relay. Still getting code 36 after operating vehicle for ten minutes at 65-70 MPH highway. No ill performance effect. Anybody? :confused:
Old Apr 22, 2004 | 04:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Code 36 at 70 MPH (JScott 88 C4)
Hmmm, that's strange code 36 is MAF Burn-Off problem.
Pull the relays & MAF sensor plug and clean all contacts; then assure that all plugs are firmly inserted into the sockets.
Old Apr 22, 2004 | 04:46 PM
JScott 88 C4
Default Re: Code 36 at 70 MPH (65Z01)
Thanks 65Z01.
Your note implies more than one relay. Besides the MAF sensor, I replaced the burn-off relay on the firewall near to the brake master cylinder. Is the another one that I missed?
Old Apr 22, 2004 | 07:56 PM
65Z01's Avatar
65Z01
There is a MAF Power Relay and a MAF Burn-Off Relay; both are behind the battery on the firewall.
[Modified by 65Z01, 7:59 PM 4/22/2004]
Old Apr 23, 2004 | 10:30 AM
JScott 88 C4
Thanks for both replies / suggestions 65Z01. Will clean connections 1st followed by 2nd relay installation, if necessary.
Appreciate the assistance. :seeya
Old Apr 23, 2004 | 11:25 AM
86VetteBill's Avatar
86VetteBill
I had an issue with this too. I swapped the 2 relays with each other and got a different code. I replace the bad one. Seems these are interchangeable on my '86.
Old Apr 23, 2004 | 11:43 AM
JScott 88 C4
Default Re: Code 36 at 70 MPH (86VetteBill)
My thoughts exactly. I still have the old relay to swap around. I can change out the new relay for other one to see if that corrects the problem. If I get another code, I'll know which relay is bad and hopefully correct the problem.
With 65Z01's advice maybe I can put this issue to rest. Thanks.
To Code 36 at 70 MPH
