Crank pulley
Old Apr 25, 2004 | 08:58 PM
Toecutter's Avatar
Toecutter
Default Crank pulley
Any advice on removing the crank pully so I can change optispark on my 93?
Old Apr 26, 2004 | 03:01 AM
BAM92's Avatar
BAM92
Default Re: Crank pulley (Toecutter)
Crank pulley is only 3 bolts and comes right off. It is the hub that you would need a puller for. Pulley only goes on one way so you don't have to mark it unless it is easier for you to find on reassembly.
Old Apr 26, 2004 | 04:51 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Crank pulley (BAM92)
On an L98 you need to remove the three outer bolts along with the center bolt to remove the crank pulley.
Old Apr 26, 2004 | 08:31 AM
Toecutter's Avatar
Toecutter
I have the 3 bolts out but she wont budge.
I guess I need a bigger hammer.
To Crank pulley
