Not sure what shes doing
Old May 5, 2004 | 09:58 AM
Johns_87's Avatar
Johns_87
Default Not sure what shes doing
Just finnished going through all the basic tuneup parts cap,wires,plugs and
rotor. Went for a ride out to the beech on sunday and almost all the way there was trafic. My vette was running about 200-220 temp and died then
started back up with no problem. After a couple of minutes the check engine light came on and stayed on for the rest of the day. Yesterday I took her out for a ride and the check engine light would not come on.When this happend it
reminded me of a vapor lock problem that I had in a hot rod years ago. I have a GM code reader!!! though I think yhe problem would have to acure for this to work correct. :confused:
Old May 5, 2004 | 10:04 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Not sure what shes doing (Johns_87)
you can still get the code, if you havent' disconnect the battery... that will help here...
Old May 5, 2004 | 10:05 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I beleive the code is stored until cleared. Take a reading :thumbs:
Old May 5, 2004 | 10:13 AM
Nathan Plemons's Avatar
Nathan Plemons
The code is stored for some very large number of key cycles. It should still be in there.
To Not sure what shes doing
