Spicer u-joints
Old May 8, 2004 | 04:53 AM
fast not first's Avatar
fast not first
Default Spicer u-joints
Since I live in The Netherlands it is not easy to get the right parts. I'm looking for the 1310 non greaseable HD Spicer u-joints for my driveshaft. At http://www.spicerdriveshaft.com/card...dan-light.html they show 2 kinds of joints and I think I need the Spicer Life ones. I have contacted the importer in my country but I need a Spicer part number, can you help me out?
Old May 8, 2004 | 07:56 AM
vetteseniorcit's Avatar
vetteseniorcit
Default Re: Spicer u-joints (fast not first)
I will contact my supplier on Monday, May 10 to see if I can get the information for you. I understand you are looking for driveshaft univeral joints (spicer) for a Corvette. Please verify they are for an 87 model year.
[Modified by vetteseniorcit, 4:58 AM 5/8/2004]
[Modified by vetteseniorcit, 5:01 AM 5/8/2004]
Old May 8, 2004 | 10:18 AM
ben73's Avatar
ben73
Default Re: Spicer u-joints (vetteseniorcit)
I bought these:
Driveshaft: 5-625X or new number SPL22-2X
Rear Half Shafts: 5-627X or new number SPL30-2X
Old May 8, 2004 | 10:37 AM
fast not first
Default Re: Spicer u-joints (ben73)
Thanks for the info! Yes it is for a 1987 with an automatic transmission. I'am looking for the heavy duty ones, the ones without the grease nipple.
The numbers they gave me in Holland are: 18100 for the normal ones with the grease nipple, 1320043 for the so called HD ones with an extra thrust washer on which they say it also has a grease nipple. It seems to me that the part numbers I mentioned are not Spicer part numbers. I have also read about coated ones for use in aluminium driveshafts.
Julius
[Modified by fast not first, 4:06 PM 5/8/2004]
Old May 8, 2004 | 11:26 AM
CFI-EFI's Avatar
CFI-EFI
The series "1310" is just a basic size. There are many Spicer part numbers in the "1310" series for different applications. There is a 1310 "wheel joint that is very common in US built 4X4 front axle shafts, for instance. You definitely do want the coated for use in aluminum shafts, u joints. Unfortunately, I don't have a current catalog. The original part number for the stock replacement joint was, "5-467X". That was the coated, with no zerk, OE joint. I understand that number has been superceded. You will be getting current part numbers posted., here, soon. Good luck, and...
RACE ON!!!
Old May 8, 2004 | 07:54 PM
86Moon's Avatar
86Moon
PN’s 5-800x for the half shafts and 5-786x for the driveline --à New PN SPL-30x half shafts and Not sure if there is a new PN for the driveline or not.
http://<a href="http://www.dana.com/.../services/</a>
To Spicer u-joints
