She Won't Start
Old May 8, 2004 | 06:41 PM
GRX's Avatar
GRX
Default She Won't Start
My 85 will spin but won't catch. During start, I can hear a slight poping at the exhaust. Very minute poping. I set ignition timing with No.1 piston at TDC and the distributor rotor pointing towards the No.1 spark plug wire. I measured 40+lbs of fuel pressure on start. Spark plugs are wet with fuel.
Any ideas?
Old May 8, 2004 | 07:04 PM
95AquaC4's Avatar
95AquaC4
Default Re: She Won't Start (GRX)
Has this been recently worked on? You mentioned a timing setting. Maybe its a Cap/rotor/plug wire situation?
Old May 8, 2004 | 07:37 PM
JAKE's Avatar
JAKE
I just posted how you should orient the harmonic damper and rotor on another post.
I just went through this same problem with another Forum member a few days ago.
Take a look. http://forums.corvetteforum.com/zerothread?id=814722
Jake
[Modified by JAKE, 6:39 PM 5/8/2004]
Old May 8, 2004 | 07:46 PM
GRX's Avatar
GRX
Default Re: She Won't Start (JAKE)
Okey-dokey. That sounds absolutley logical. I will try it.
Old May 8, 2004 | 07:48 PM
GRX's Avatar
GRX
Default Re: She Won't Start (95AquaC4)
Yep. Had the intake manifold off to fix a sealing issue. Then put put it back the same way and whamo!
Old May 11, 2004 | 11:16 PM
GRX's Avatar
GRX
Well,I tried it but she still won't start. This time got a massive backfire through the manifold. What could it be? Did I adjust the valves wrong? :(
Old May 11, 2004 | 11:20 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Bad timing or bad valve adjustment will cause that. Have you checked rotor relationship to cap at #1 tdc compression.
How did you set your rockers ?
Old May 11, 2004 | 11:22 PM
GRX's Avatar
GRX
Default Re: She Won't Start (AGENT 86)
Per the GM manual. ...finger tight to remove play or lash, then one complete turn clockwise....
Old May 11, 2004 | 11:32 PM
AGENT 86's Avatar
AGENT 86
Is that finger tight with the lock nut or spinning pushrod ?
If your confident with your adjustment than I would look at spark plub wiring and initial static timing. :cheers:
Old May 11, 2004 | 11:35 PM
GRX's Avatar
GRX
That would be spinning pushrod....
Old May 11, 2004 | 11:46 PM
AGENT 86's Avatar
AGENT 86
Your grip could be stronger than you think
Are these stock rockers or roller ?
Old May 11, 2004 | 11:49 PM
GRX's Avatar
GRX
There're full roller rockers. Would that matter?
Old May 11, 2004 | 11:51 PM
TIMSPEED's Avatar
TIMSPEED
DING DING DING!!!! Your distributor is 180º off. Pull it out and spin it around, and you're good to go.
Old May 11, 2004 | 11:55 PM
GRX's Avatar
GRX
Default Re: She Won't Start (TIMSPEED)
Really? I looked in the number one spark plug hole and could swear I could see the piston top when I set the rotor. :confused:
Old May 12, 2004 | 12:13 AM
AGENT 86's Avatar
AGENT 86
TDC compression happens once every two revs. If you don't verify that it's on compression stoke, you could be 180 out. Put your finger in the hole and turn it over till you feel the pressure and then line up the mark on the balancer.
:cheers:
Old May 12, 2004 | 12:16 AM
FD2BLK's Avatar
FD2BLK
Yes but the #1 piston is at TDC twice once for compresion and once for exhast sroke. The only way to tell is to pull the valve cover. The compresion stroke will hapen rite after the intake valve close. BTW I think you are way to tight on the R/Rs as well should be between 1/4 and 1/2 turn past zero lash 1 full turn is to much
Old May 12, 2004 | 12:18 AM
AGENT 86's Avatar
AGENT 86
No, I just found it easier to set rollers as the nut can be turned by hand to remove lash. The stockers are a stover type lock nut and a ratchet is needed, thereby eliminating any real feel. :cheers:
To She Won't Start
Old May 12, 2004 | 12:19 AM
GRX's Avatar
GRX
Default Re: She Won't Start (FD2BLK)
Not sure but I think the GM manual specs one turn.
Old May 12, 2004 | 12:23 AM
FD2BLK's Avatar
FD2BLK
They do and they are wrong. I can tell you if you go 1 full turn past zero lash with R/Rs it will probably run but your valves are probably not closing all the way either.
here is a link that explains it fairly well http://www.centuryperformance.com/valveadjustment.asp
Old May 12, 2004 | 01:30 AM
JAKE's Avatar
JAKE
[SNIP] Did I adjust the valves wrong? :( [/SNIP]
Yes in deed, you have.
Jake
