1988 - any problems with using scanning software ? 160 or 8192baud?
Old May 10, 2004 | 07:30 PM
Stingraynut's Avatar
Stingraynut
Default 1988 - any problems with using scanning software ? 160 or 8192baud?
Last year I downloaded a copy of Win ALDL and installed it in a laptop.
The Laptop and cable were verified working on an 84 but won't work on my 88.
I can check sys codes manually with the paperclip method and have tested the relevant plug holes in the ALDL socket, using led's showing there is transmission of some sort active there.
I've verified that the cable is making good connection.
Is anyone with an 88 using Win ALDL or had trouble ?
I'm told that the Win ALDL program works on 160baud, and that from 86 on both 160 and 8192baud were available.
I don't know enough about this stuff, so I'm hoping other with 88 vette's can tell me what scanning software works on their cars.
thanks
S'nut
Old May 10, 2004 | 07:58 PM
Upstate's Avatar
Upstate
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
Default Re: 1988 - any problems with using scanning software ? 160 or 8192baud? (Stingraynut)
I just started using WinALDL for my 88 and built my own cables, works like a champ. I don't know enough to tell you if the pin outs on the ALDL from an 84 are different than the 88
Anyhow, if you know the cable is correct and should work, did you place a 10K Ohm resistor across pins A & B of the ALDL?
Old May 10, 2004 | 10:48 PM
Stingraynut
Default Re: 1988 - any problems with using scanning software ? 160 or 8192baud? (Upstate)
Hi Upstate, thanks for replying. So now at least I know that WIN ALDL should work on an 88.
Yes the resistor is there. Brown/Black/Orange/Gold.
A friend with an 84 made the cable for me. We tested the cable and my laptop on his 84 and everything worked.
I get no response from my 88.
My friend told me a way to test my ALDL socket using led's and there was some action at the pin outs proving a connection to the ECM.
I installed Win ALDL on a borrowed, almost new, laptop and still nothing.
I've just borrowed a 8192baud comm cable and got the free Moates software. Hoping that perhaps the 88 needs a higher speed connection.
Unfortunately when I went to connect up last night, there was no serial port in our brand new laptop to plug the cable into!!!!!
Things seem to be getting worse, not better.
I'd appreciate any info on any of this -
S'nut
Old May 11, 2004 | 12:24 AM
Bluevette85's Avatar
Bluevette85
Winaldl can only read at 160 on your car. Try Datamaster. It will work at the higher rate and can be used with USB.
www.ttspowersystems.com
Old May 12, 2004 | 09:50 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There is a chance that your data out of aldl connector may be "M".
They did change, not sure when or why. On my 86 it's "E"
Old May 12, 2004 | 08:39 PM
Stingraynut
Default Re: 1988 - any problems with using scanning software ? 160 or 8192baud? (AGENT 86)
Hi Agent 86, you may be on to something - I was using A B and E with Win ALDL and getting nothing. Maybe I should have tried M
Does anyone know which to use for an 88 ?
BTW, I read the sad story about your vette protector, great looking animal. Sorry for your loss.
S'nut
Old May 21, 2004 | 03:53 PM
mao2192's Avatar
mao2192
I have an 88 and built a cable and successfully got full readouts.
I followed the instructions on the website for the cable. I have one wire going to A and one to E with a 10k resistor between A and B. i used the 2N3904 transistor (if i remember correctly). I dont use R4.
http://winaldl.joby.se/interface.gif
I didnt change any settings on my laptop to get this to work so whatever the default was worked fine. In WinALDL i see the little box up top blink every second or so with a value of 25. If you get red blinks or none at all its probably a bad connection @ the diag. terminal.
I've got one of those "code scanners" (or paperclip in plastic) that blinks your check engine light, i think ill wire my cable to that thing so it stays in the diag. term. better :P.
hope it helps or at least gives you the hope that it will work someday. If you arent convinced and want pictures, let me know and ill take some. it should just work though.
[Modified by mao2192, 8:55 PM 5/21/2004]
Old May 21, 2004 | 07:41 PM
Stingraynut
Default Re: 1988 - any problems with using scanning software ? 160 or 8192baud? (mao2192)
Thanks for the info mao2192, you're right, it does give me hope.
So far I've had no luck getting a connection. My ALDL socket has the following wires -
A Black/white stripe
B White/ Black stripe
C Brown
E Orange
F Tan/black strip
G Red
I have the service manuals and have spent ages looking for the ALDL socket to check if a wire is in the wrong hole or missing. I'm sure I've have seen it in the electrrical manual so am now going through it page by page - I'll be an expert on everything when I'm finished !
I recently got the 8192 baud cable to use with Moates software, it has 4 wires, one going to 'M' but I have no wire there.
I think this means I don't have 8192 signal ?
S'nut
Old May 21, 2004 | 08:31 PM
AGENT 86's Avatar
AGENT 86
Try moving the moates cable from "M" to "E"
Here is some good info
Please note: Biggest FAQ: Why won't it connect? Here's a short list
of the most common reasons:
1) Check your defaults options (menu item 8) and make sure your
ECM type (165 or 730) is properly selected.
2) Make sure your default setting is in the 'Diagnostic ECM Mode',
because the program is 'shipped' in the 'Offline' mode. Offline mode is
just so you can navigate through the program without having an interface
to the car connected.
3) Check your circuit connections. If you need a power supply make sure
it's connected. If you have a 165 MAF ECM, make sure you have a 10k
resistor installed between ALDL pins A&B.
4) Go into your PC's BIOS and disable any IR/DA port stuff, and make
sure your COM ports are subsequently enabled.
5) Don't use WinXP, WinNT or anything like that. The program likes
MSDOS, Win95, and Win98.
Old May 22, 2004 | 02:05 PM
Stingraynut
Thanks Agent 86. The Moates cable has 4 wires, A B E and M - do you mean disconnect E and put the M lead in E ?
The Moates cable came from MaStach.com and is for TPI GM OBD1 so I'm assuming it has the resistor between A and B
(The Win ALDL cable has the resistor and 3 wires - but that's been proven to work on an 84)
Thanks for the FAQ info, I'll check all that out. I did go to options and changed to 'Online' and selected my ECM type of 165.
Number 4 is tricky, I've never been into the BIOS. I'm unsure where to start.
Our old laptop was Win NT, but the WIN ALDL program and cable on it worked on an 84.
Our new laptop is Win XP but there's no serial port ! Until I confirm that I have communication between my car and a computer, I'm driving around to my nephew and using his new laptop which does have a serial port but is Win XP - so it's not very convenient.
Am I just wasting my time trying with Win XP ?
S'nut
Old May 24, 2004 | 10:13 AM
AGENT 86's Avatar
AGENT 86
I believe winaldl and moates don't work with XP. Maybe Datamaster does though. The cable must have a wire at "M" and "E" to cover different years data output. If your using XP that could be the problem
Good Luck
Old May 24, 2004 | 05:31 PM
Stingraynut
Hi Agent 86, I don't have a wire at 'M'. I can't find the relevant page in the service manual that would show what wires should be there.
I'm borrowing the XP laptop for 2 days, to instal some virus software (but mainly so I can have more time with it and my car.)
Looks like I should give up on the Moates and try and get WinALDL to work. As I mentioned before, Win ALDL, the old laptop that had a serial port and the Win ALDL cable all worked on an 84 but wouldn't in mine.
The problem must be in my car. The paperclip test works fine and so does the digital dash - which from memory verifies that the three wires A B and E are all working.
It's a frustrating mystery.
S'nut
Old May 24, 2004 | 08:18 PM
korvette4u's Avatar
korvette4u
S'nut
hi S'nut....try here.....may answer your problem...... http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm make sure you read all the links that page should answer every question you have...
once your have read all, get datamaster software.. i can help with that..
To 1988 - any problems with using scanning software ? 160 or 8192baud?
