Injector size.
Old May 11, 2004 | 03:37 PM
devilfish's Avatar
devilfish
Default Injector size.
Will my stock injectors max out with 420/430 hp @ 6000rpm??
What do I need?
Old May 11, 2004 | 04:02 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Injector size. (devilfish)
Do you expect 420-430chp from your setup?
Old May 11, 2004 | 07:39 PM
BAM92's Avatar
BAM92
Default Re: Injector size. (65Z01)
Jayson at MTI always told me 24# injectors were good up to 450 hp.
Old May 12, 2004 | 01:48 AM
devilfish's Avatar
devilfish
yes I do. My setup is:
LT1 intake
AFR 195 heads
hotcam
1.6 rockers
hooker headers
SCAT 9000 crank
SRP 10.3:1 fordge pitons
fordge I-beam rods.
should be good to 430 at the crank.
To Injector size.
