fuel filter location
Old May 12, 2004 | 08:28 PM
mjfox's Avatar
mjfox
Default fuel filter location
Any one know where it is on a 1990 is it easy to remove
how much do they cost
thanks mike
Old May 12, 2004 | 08:35 PM
rons85's Avatar
rons85
Default Re: fuel filter location (mjfox)
right side frame rail just behind the front tire - sort on under the passengers feet. Easy to get to from underneath. It's the standard GM EFI filter - same one most 80's GM's use - about 20 bucks at any parts store in the world.
Old May 12, 2004 | 09:57 PM
corsair666's Avatar
corsair666
2nd Gear
The cost is right around $10.00 at the discount auto parts stores.
Make sure that you run the gas tank down as much as you can in order to lower the static pressure at the filter when you remove it. Also a good strategy to change out the filter after letting it sit over-night.
Old May 13, 2004 | 06:28 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
As others have said, under the passenger side right next to the frame. There is a metal plate that covers it. As I recall it has three bolts to remove it. Be sure to open the gas cap to relieve the pressure before you remove the filter. If you don't the pressure will push out a lot of gas. I learned that the hard way. It is not a bad job once you get the car high enough off the ground.
Old May 13, 2004 | 10:30 AM
GKK's Avatar
GKK
Default Re: fuel filter location (joecaver)
See my C4 Tech Tip write up under the Tool bar for "89 fuel filter replacment" near the top of the tech section.
To fuel filter location
