Wheel bearings
Old May 14, 2004 | 10:26 AM
Blow Torch's Avatar
Blow Torch
Default Wheel bearings
Where is the best place to purchase (price) rear wheel bearing assemblys?
Old May 14, 2004 | 10:29 AM
scorp508's Avatar
scorp508
Default Re: Wheel bearings (BOTTLE FED)
For me Pepboys @ $139.99 with lifetime warranty.
Old May 14, 2004 | 10:31 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The local AutoZone's and Carquest's have the same parts found in the catalogs for much better prices. I paid 135 apiece at my local CarQuest store.
:cheers: -JRC-
Old May 14, 2004 | 10:40 AM
Blow Torch's Avatar
Blow Torch
Default Re: Wheel bearings (JrRifleCoach)
Thanks guys :seeya
Old May 14, 2004 | 03:16 PM
mik's Avatar
mik
I bought the rears at AutoZone for about $100.00 each. They were manufatured by Timken. So far they're fine.
Old May 15, 2004 | 12:58 AM
John A. Marker's Avatar
John A. Marker
I checked the usual (Ecklers etc) and auto parts houses. Ended up checking bearing supply companies and bought from them a good quality US MADE bearing. You may want to consider buying a TORX screw bit made for an IMPACT. I twisted a standard Torx bit almost 90 degrees trying to remove the screws from the old bearings. The impact bit made the difference! Good LUCK, :cheers:
Old May 15, 2004 | 01:44 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: Wheel bearings (John A. Marker)
I got a pair of rears for $215 in a special purchase from The Last Detail a while back. Just saving them until I need them.
Old May 15, 2004 | 04:03 AM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
The Pep Boys wheel bearings may look cheap, but the manufacturer is NDH who was the OEM manufacturer for GM bearings for the C4. Some might say that the Timken bearings are better than the NDH, but no matter where you buy the bearings, if they have NDH molded into them you are getting a GM original equipment part. With the lowest price and a lifetime warranty on NDH made bearings the PepBoys units are a good deal.
Old May 15, 2004 | 04:20 AM
Frizlefrak's Avatar
Frizlefrak
Default Re: Wheel bearings (Mike_88Z51)
Another vote for Pep Girls. Lifetime warranty is hard to beat....and they are nationwide. No problems so far.
Old May 15, 2004 | 10:14 AM
Monks's Avatar
Monks
The "Last Detail"/ Atlanta Corvette has an ad in the new Vette Fever
for $105 each.
Russ
To Wheel bearings
