HOOD POPS OPEN
Old May 19, 2004 | 09:50 PM
LT1 TOY's Avatar
LT1 TOY
Default HOOD POPS OPEN
HOOD POPS OPEN ON PASSENGER SIDE SOMETIMES. HOLDING CLAMP LOOKS WORE.WHAT SHOULD I DO?
Old May 19, 2004 | 11:16 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Default Re: HOOD POPS OPEN (LT1 TOY)
Not sure what you've got but on my 90 I had that prob and simply adjusted the cable a bit ..has independent adjusters for both right there at the catches on both sides. try letting out a tad of cable..not too much though or it wont open. But if it's truely worn out I'm not sure what you could do. good luck:seeya
Old May 20, 2004 | 12:29 PM
Unriced's Avatar
Unriced
Try what Dave suggested and if that doesnt work, you can try
readjusting your hood catches, they screw in and out...
Careful, a little goes a long way... Make sure your cable isnt
frayed on the passenger side too.. I doubt the clamp is worn
that badly...Good Luck..
To HOOD POPS OPEN
