need injectors and support please help
Old May 22, 2004 | 02:27 PM
jetscreamer's Avatar
jetscreamer
Default need injectors and support please help
I just bought an89 that idles rough when it warms up .car has k&n gutted afm tb air fiol long tubes catco flomasters hiper tech coil msd8.8 msd6a{not hooked up} havent checked for chip yet {can you tell} when warm 4 injectors omed under 12 they are a lite greenish plastic in color w/ a silverish metal on bottom. all smog is still in tact i live in ca. can these be stock inj. 22lbs? motor is strong 150000 mi on clock newer gaskets top an bottom. what is a safe inj # good to use with just these bolt on mods. should i rebuild these ? where . adjustable fpr may be, does anyone have this stuff for sale please HELP! :confused:
[Modified by jetscreamer, 7:28 PM 5/22/2004]
Old May 23, 2004 | 08:19 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: need injectors and support please help (jetscreamer)
Moving to C4 Tech
Old May 23, 2004 | 10:37 PM
87NassauBlue's Avatar
87NassauBlue
The blue ford mustang svo injectors are a great upgrade. You can get a set on ebay for $100 - $150. I got my new ones cheaper than I could rebuild the old ones.
Old May 23, 2004 | 10:39 PM
87NassauBlue
Default Re: need injectors and support please help (87NassauBlue)
by the way, they are 24 pounders and depending on what fuel pressure you run, you can run them up to about 30 or so
To need injectors and support please help
