Real bad memory!
Old May 24, 2004 | 01:43 PM
HoustonBob's Avatar
HoustonBob
Default Real bad memory!
Okay, I am getting old for sure.
Can someone tell me where the feed side of the tranny cooling lines go into the radiator? It has been 6 months since I pulled this stuff out and I cannot remember if it went from the pump side of the tranny to the top or the bottom of the radiator?
Thx!
RC
Old May 24, 2004 | 08:02 PM
Wheelman's Avatar
Wheelman
Default Re: Real bad memory! (HoustonBob)
In the top out the bottom I believe
Old May 24, 2004 | 08:08 PM
JAKE's Avatar
JAKE
Default Re: Real bad memory! (Wheelman)
:iagree:
Jake
Old May 24, 2004 | 08:27 PM
CFI-EFI's Avatar
CFI-EFI
Put the lines where they fit best. First, that is probably where they were, and second, there is nothing "directional" about the cooler. It wouldn't matter.
RACE ON!!!
Old May 25, 2004 | 02:07 AM
JAKE's Avatar
JAKE
Default Re: Real bad memory! (CFI-EFI)
RACE ON!!!
Unless you're installing a trans cooler, then the recommended routing is to tie the aux cooler in to receive the fluid AFTER the fluid has gone through the factory cooler.
So you'd need to use the lower line on the factory cooler (radiator) to run to the aux cooler; then out of the aux cooler back to the trans.
Jake
Old May 25, 2004 | 09:54 AM
HoustonBob's Avatar
HoustonBob
Default Re: Real bad memory! (JAKE)
Thanks All!
I am installing a factory cooler as well. Maybe I was making it more complicated. Looking at the motor side, hot water starts at the bottom and re enters at the top, which led me to think maybe the transmission fluid should do the same, so as not to hot the hottest part of the radiator on the way back.
More than likely does not make a difference.
Thanks again. Someday I will get this thing off the stands!
RC
:cheers:
To Real bad memory!
