Dave Stone's 9-second C4 - blown intercooled
Old Jun 14, 2004 | 07:56 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Dave Stone's 9-second C4 - blown intercooled
I used to drag race with this guy down in Texas.
http://www.corvettemagazine.com/2001...ette/fsv-1.ASP
Check out the intercooler
Old Jun 15, 2004 | 12:31 AM
Bruce's Avatar
Bruce
Default Re: Dave Stone's 9-second C4 - blown intercooled (BrianCunningham)
This IC setup was built by Keith at Forced Fed Performance. And he wants a load of $ for the IC setup, while back ago TJ has asked Keith about the cost of it.
Bruce
[Modified by Bruce, 11:36 PM 6/14/2004]
Old Jun 15, 2004 | 09:01 AM
Baldturbofreak's Avatar
Baldturbofreak
Default Re: Dave Stone's 9-second C4 - blown intercooled (Bruce)
I like water/air- half the room same cost and over 100%eff if your tricky...
Old Jun 15, 2004 | 11:07 AM
tjwong's Avatar
tjwong
Default Re: Dave Stone's 9-second C4 - blown intercooled (Baldturbofreak)
What I want to know is what his tranny and OD looks like. He has a gear vendors OD unit connected to the back of the TH400 tranny. I very curious as to how his C beam connects. I have a water to air intercooler in my truck, and sure if you got it loaded with ice it can do better than 80% but in a daily driver with a water pump and an radiator to get the heat out of the IC coolant, its not near 100% or even 80%. On the freeway I can see better but in traffic that coolant rapidly gets hot after absorbing engine compartment heat. For a race car with a large resorvoir where you can drain and load it with ICE I can see a definite advantage. I guess one could rig up a CO2 bottle and spray it on the IC which would fog it with dry ice and drop the temperature way down...... Or do as the ricers do and spray it with liquid NOX
Old Jun 15, 2004 | 02:15 PM
krivera's Avatar
krivera
Default Re: Dave Stone's 9-second C4 - blown intercooled (tjwong)
sweet!
Old Jun 15, 2004 | 05:23 PM
Baldturbofreak
Not ice, brother, drive around using my a/c to freeze the liquid, unless you cruz under boost you have 7 gallons of ice cold water waiting to take your intake temps below ambient.
Old Jun 15, 2004 | 05:27 PM
Baldturbofreak
A short burst w/ air to air is about 55-60% effficient. A steady state (high constant speed) is around 25% efficient. An air to air intercooler doesnt actually do any heat exchange until the event is over. Your using the thermal inertia of the aluminum in the int. core to do the job of cooling the charge, then the heat is exchanged into the environment.
Old Jun 29, 2004 | 01:22 AM
amm0bob's Avatar
amm0bob
From: The last place on earth to get cable... Sacramento
Sweet car
Old Jun 29, 2004 | 11:29 AM
jburnett's Avatar
jburnett
Bruce
No it wasn't...It was built by Bobby Shahan of Shanan Race Cars in Cabot, Arkansas... He's done four of them, three Vettes and one T/A. He's my chassis builder and does ALL of the plumbing work for Aaron and John with Absolute Performance (Gwatney Chevrolet). It's as trick as they come, I've learned EVERYTHING about that type of fab work from Shahan; I was there when he built two of them. They are "ne plus ultra" of the i/c plumbing. The flat tubing was built using 2" aluminum tubing cut in half and .100" flat plate, all TIGed together. It's the most intricate i/c plumbing I've ever seen.
-Jeb
PS- Shahan modified the stock torque arm too... It's only about 15" long now. But, the TH400/GV package looks like it's factory. David was considering selling it awhile back and I was going to buy it but he decided to keep it.
[Modified by jburnett, 4:32 PM 6/29/2004]
To Dave Stone's 9-second C4 - blown intercooled
