Narrow body roller rockers?
Old Jun 26, 2004 | 05:38 PM
devilfish's Avatar
devilfish
Default Narrow body roller rockers?
Do I need narrow body roller rockers or will any brand/type do?
Old Jun 27, 2004 | 08:08 AM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: Narrow body roller rockers? (devilfish)
we probably need a little more info anders. what type if heads are you running etc.
Old Jun 27, 2004 | 11:21 AM
devilfish's Avatar
devilfish
Default Re: Narrow body roller rockers? (atotalnincompoop)
sorry..
I havent decided on heads yet, but it will be one of these 3. AFR, CANFIELD, TRICKFLOW, depending on my budget after the rebuild, and cam choise.
Why I ask is that i got a good deal on used roller rockers, comp cams, and they are listed as "normal" and not Narrow body style rockers. I didet know that there where 2 kind of roller rockers?
Regards
Old Jun 27, 2004 | 12:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
CC Pro Magnums will fit stock #113 heads and AFRs (with a little work inside the valve covers) but I'm not sure about Trick Flow or other heads.
If you don't get the answer here, try the potential head mfgs web site and tech support.
Old Jun 27, 2004 | 12:28 PM
devilfish's Avatar
devilfish
Default Re: Narrow body roller rockers? (65Z01)
thanks 65z01 will do.. What is it that can make a roller not fit? Cylinder bolt heads?
Old Jun 27, 2004 | 12:29 PM
tjwong's Avatar
tjwong
If anything all you have to do is to grind off the drip tabs in the magnesium valve covers. The LT1 style plastic covers bolt on without any problems using, Comp, Crane or Crower rollers rockers in either narrow body or standard designs.
Old Jun 27, 2004 | 03:34 PM
65Z01's Avatar
65Z01
Default Re: Narrow body roller rockers? (tjwong)
When I put 1.6:1 ProMagnums on my stock #113s with stock valve covers I had to grind down the drip tabs and narrow the bolt towers inside the valve covers but had no fitment problems with either the vent or PCV area.
I believe TF heads have the valves offset a little from the position in stock heads so wonder if that could cause some fitment problems with the ProMags. But TF tech support should be able to answer that question.
To Narrow body roller rockers?
