woohoo, engine coming together!
Old Jun 27, 2004 | 07:27 PM
Red Tornado's Avatar
Red Tornado
Default woohoo, engine coming together!
Just thought I'd share the progress......engine is back with my mechanic (see below) after long stint at the machine shop (minor block decking, cylinder wall re-hone, all new: freeze plugs, main/cam/rod bearings, ARP main cap studs, ARP rod bolts, plasma-moly piston rings, crankshaft turn/polish & balance to factory specs, repaint, etc.).....installed at this point is the LPE 219 cam, AFR/TPIS heads, damper, new oil pan/pump assy......next are the Pro Magnum RR's, SR base which is just resting on top & rest of intake, etc......
Wanted to show a view of those gorgeous heads w/titanium retainers & 10* locks
Will report on further progress.....
[Modified by bradvette, 7:31 PM 6/27/2004]
Old Jun 27, 2004 | 07:31 PM
STL94LT1's Avatar
STL94LT1
Default Re: woohoo, engine coming together! (bradvette)
Sounds like a strong combination.
Old Jun 27, 2004 | 08:23 PM
JackDidley's Avatar
JackDidley
Old Jun 27, 2004 | 08:25 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
When will you be cruizin Brad
Old Jun 27, 2004 | 08:30 PM
Red Tornado
Default Re: woohoo, engine coming together! (AGENT 86)
hopefully in about 10 days! its been down since 4th of may
To woohoo, engine coming together!
