SPARK PLUG REMOVAL ON RHD C4
Old Jul 7, 2004 | 03:00 AM
smacko's Avatar
smacko
Default SPARK PLUG REMOVAL ON RHD C4
HOW THE HELL DO YOU GET THE REAR DRIVERS SIDE SPARK PLUG OUT OF A RIGHT HAND DRIVE C4??????????
I KNOW I've done it before but damned if I can find anywhere with sufficient leverage to get it out!!! :mad
Old Jul 7, 2004 | 03:09 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Default Re: SPARK PLUG REMOVAL ON RHD C4 (smacko)
Get one of these before your next plug change..it's a vette owners delight.
http://www.madvet.com/-/shop?frame=1.173
[Modified by skateparkdave, 2:12 AM 7/7/2004]
Old Jul 7, 2004 | 03:20 AM
smacko's Avatar
smacko
Default Re: SPARK PLUG REMOVAL ON RHD C4 (skateparkdave)
It's ok; the answer to my own stupid question is to put a socket on the end of the plug socket and presto! You wouldn't believe how many different tools I went thru before I came up with THAT bright idea!
linkschamp's Avatar
linkschamp
Dayum... that looks cool - does it work as good as it looks?? This has to be a very well kept secret...
Old Jul 7, 2004 | 03:27 AM
skateparkdave
Default Re: SPARK PLUG REMOVAL ON RHD C4 (linkschamp)
With 3" and 6" extensions as needed and 3/8's socket it's great!
Old Jul 7, 2004 | 03:47 AM
smacko's Avatar
smacko
The plug I was concerned with HAD no room for any extensions.
Old Jul 7, 2004 | 09:06 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I just used one of those for some plug removal 2 days ago. The only problem is it is a bit thick through the head making it hard to get into a tight space. It will not give enough leverage to bust the plug loose, but it is a great way to unscrew it after you get it loosened. Well worth the money though when it fits your space and it looks so cool in your toolbox!
Old Jul 7, 2004 | 11:31 AM
smacko's Avatar
smacko
Default Re: SPARK PLUG REMOVAL ON RHD C4 (corvetteronw)
Like I said (or implied) a 19mm socket on the end of the spark plug socket does the trick!
Old Jul 7, 2004 | 11:36 AM
Steel Blue 91's Avatar
Steel Blue 91
You're talking about #8 plug, right? I just use a spark plug socket with a 3/4 inch open end wrench. The back end of the socket was manufactured to work like a 3/4 inch nut. Works like a champ.
Old Jul 7, 2004 | 12:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: SPARK PLUG REMOVAL ON RHD C4 (Steel Blue 91)
That's my method on the right rear too; it should work on the left rear with RHD I would think.
Old Jul 7, 2004 | 12:12 PM
vvv90's Avatar
vvv90
Default Re: SPARK PLUG REMOVAL ON RHD C4 (65Z01)
I've said it before and I"ll say it again. Taking off the fenderwells does miracles for changing plugs.
Old Jul 7, 2004 | 12:15 PM
smacko's Avatar
smacko
Thanks guys...Tried that one but didn't have enough clearance to really get much leverage (Ex. Manifold AIR piping was in the way); might depend on the length of the wrench (Us Aussies call them spanners-aren't we strange?!) ehhee
As for fender removal...I'm sure I read that it's easier 2 remove engine when performing basic tune up's!
Old Jul 7, 2004 | 12:37 PM
vvv90's Avatar
vvv90
Being a smarta$z? Good one. Insult people giving advice. Are you saying it's easier to remove the engine than the fender wells? WTF?
Whatever, anyway...
Just so you know, it only takes about 5 minutes to remove them and allows you to use only a swivel head and 3" extension for all plugs. Not to mention saves your knuckles.
But what do I know, you're the one who's in such a tough spot that you had to take the time to post a thread on the subject of removing spark plugs. Not a big deal, people do it all the time. But don't be surprised if someone actually gives you advice on a better way to do things....afterall, isn't that why you asked us?
Do you think I get off on telling fellow forum members the hard way to do things?
Old Jul 7, 2004 | 02:47 PM
skateparkdave
I guess my hands are just strong Naw j/k, I have had that prob with one or 2 plugs but I just slide a small piece of steel tube over handle of sidewinder to get the leverage needed. It helps for me but I guess whatever method someone finds that works for them is good
Old Jul 7, 2004 | 08:50 PM
smacko's Avatar
smacko
Default Re: SPARK PLUG REMOVAL ON RHD C4 (vvv90)
Whatever, anyway...
vvv90 - Mate, I think you have some unresolved issues from your childhood! I WAS JOKING!!! I thought THAT would have been OBVIOUS! I was not insulting ANYONE, OK? I posted it because I was stuck - I respect ALL answers THAT's why I use the forum. I'm SORRY if YOU found it offensive - was just a little light-hearted chuck off at awkward fiddly things, not at anyones (Including your) reply...OK???
[Modified by smacko, 11:51 AM 7/8/2004]
Old Jul 7, 2004 | 08:54 PM
smacko's Avatar
smacko
Thanks skateparkdave; yes, I used a steel tube as leverage for one of mine too. I reckon that I had installed the previous set too tightly; a left over habbit from years gone by. (PS; I most likely STILL installed THESE new ones too tightly, but I tried to stop myself from going overboard at least)
Old Jul 12, 2004 | 03:22 PM
vvv90's Avatar
vvv90
ahem....Well, my advice to colleagues and coworkers seemed to be falling on deaf ears that day....seemingly coincidental, but your reply did help me vent a little.
No unresolved issues, I just need a new job.
Sorry about that.
To SPARK PLUG REMOVAL ON RHD C4
