89 turn signal cam replacement
Old Jul 8, 2004 | 09:31 AM
sdharley's Avatar
sdharley
Default 89 turn signal cam replacement
Has anyone done this and have any hints, Some pic's or a diagram
Old Jul 8, 2004 | 09:51 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Send me your email address and I'll email the section from my 86 manual
Old Jul 8, 2004 | 02:06 PM
sdharley's Avatar
sdharley
Default ttt
ttt
Old Jul 8, 2004 | 04:05 PM
brookman's Avatar
brookman
Not very hard at all if you have the right tools. You need a lock plate compressor. make sure you pay attention to the orientation of the u shaped clip that you remove. then it is just 3 or 4 phllips screws ro remove the plastic turn signal assembly. one screw to remove the turn signal handle. THen you need to go to the bottom (mid) of the column and disconnect the connector. Make sure that you tie a string to the connector that you pull up through the column so that you can use the same string to pull the new one back down.
To 89 turn signal cam replacement
