conversion 86 block to roller
Old Jul 25, 2004 | 11:59 AM
tjwong's Avatar
tjwong
Originally Posted by 383 tpi
if you have part # 17120070 i am sure we can make a deal, once again thank you for the help
I have 18 of the above part number lifters. You can send me an email if you want them: tjwong@qwest.net
Old Jul 25, 2004 | 02:25 PM
comp's Avatar
comp
e-mail sent
Old Jul 25, 2004 | 04:14 PM
ben73's Avatar
ben73
Originally Posted by comp
i thought i could grind clearance and use the V8 rollers
Nope, the V8 lifters are about 0.400" too tall, the V6 lifters are perfect height... but you have to watch the base circle of the cam...
Old Jul 25, 2004 | 04:27 PM
hngacurv's Avatar
hngacurv
If anyone needs the pics hosted just IM me.
Old Jul 25, 2004 | 04:30 PM
comp's Avatar
comp
Iplaned on haveing the stock roller cam reground... plan was to
have smaller base circle and a little hotter profile, looked into price's
add 1-125 buck's for a regrind... see how my plan seamed GOOD
Old Jul 25, 2004 | 05:04 PM
comp's Avatar
comp
Oh and i planed on diff. push-rods
Old Jul 25, 2004 | 09:58 PM
comp's Avatar
comp
any body had a can ground ???
Old Jul 25, 2004 | 10:23 PM
SBNova's Avatar
SBNova
A reground or even a small base circle cam will not yield the required clearance to run OEM V-8 roller lifters. The oil "band" on the lifter body is VERY out of the lifter bore on a non-roller block. Its not even close. I beleive the .400 previously stated, but I didnt measure it myself. If you run the OEM V-8 roller lifters in a non-roller block you will have ZERO oil pressure. It will all bleed right out of the lifters. Seriously.Not even close.Will not work. The 60 degree SEFI V-6 lifters are the ONLY non-aftermarket lifters that will work. Period. Sorry to ruin your day...
Old Jul 25, 2004 | 11:01 PM
comp's Avatar
comp
i don't want to believe you, BUT you sound like you know what you are talking about...... where can i get spec's .... to measure ????
Old Jul 25, 2004 | 11:35 PM
ben73's Avatar
ben73
comp,
I have done this conversion. You need the V6 lifters. The v8 lifters will need to drop about 0.400" to be in the correct spot. You cannot grind this much off your cam....
Old Jul 26, 2004 | 03:37 PM
comp's Avatar
comp
crap anybody need any V8 rollers
for a project??????
Old Jul 26, 2004 | 08:10 PM
vetster86's Avatar
vetster86
Just my two cents, sounds like a lot of trouble time and money just to have a roller cam. Why not just get the right flat tappet for your setup.
Old Jul 26, 2004 | 09:45 PM
  #33
comp's Avatar
comp
performance
