conversion 86 block to roller
Old Jul 17, 2004 | 01:43 AM
383 tpi's Avatar
383 tpi
Default conversion 86 block to roller
I have bought a roller cam from comp, now for the harder part, how do i convert my block to roller without aftermarket rollers? , I am told it is not that diffacult to use factory parts with this motor , but i need a little advice on how to do it, any sugestions?
Old Jul 17, 2004 | 02:56 AM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Thing I discovered while buliding my 400 stroker
I ve heard that you can use the V6 rollers lifter.
Then you will need diffent length push rods.
Is the cam a small circle base cam?
I'm sure other people will chime in....
Old Jul 17, 2004 | 05:29 AM
ben73's Avatar
ben73
I have done it.
Send me and email and I'll send some pics back to you.
Ben.
Old Jul 17, 2004 | 06:35 AM
Sunyi's Avatar
Sunyi
Originally Posted by ben73
I have done it.
Ben.
Couldent you please post them on the forum as I am interested as many others?
Old Jul 17, 2004 | 11:06 AM
SBNova's Avatar
SBNova
I am about to do it. The parts are difficult to find. The lifters need to be from a V-6 chevy, and only the SEFI V-6 has a roller cam setup. I searched the V-6 forums like 60 degree v-6 something.com and a j-body.com site. They are the ones hopping up these motors so I figured they would be the ones with cheap spare parts. I know the figure eights dont clear the valley walls on a 283 block I tried them on, I head they interfere on 350's as well but I havent tried. The figure eight's and spider are easy to find on EBAY. The block must be drilled and tapped to retain the spider- which iis help to the valley with three bolts. Drilling and tapping these will probably require a complete teardown to thoroughly clean the block of debris. The holes go right into a main oil galley. I have not measured push rod length but I heard that 351 Ford pushrods are the correct length off the shelf. I hope this helps.
Old Jul 17, 2004 | 11:18 AM
Pete K's Avatar
Pete K
For the price difference between the new retro fit stuff and the new oem parts I cant see the savings in the conversion. If you were reusing known good used parts I can see it being worth the effort. If anyone follows through on this I woud be interested in the results.After spending $700 on cam,lifters and pushrods, I would like to know a cheaper way to do it next time.
Old Jul 17, 2004 | 11:20 AM
tjwong's Avatar
tjwong
If you need a set of V6 roller lifters I may have a brand new set. The ones I have are for a 3.2L or something like that. Do your research then get the GM Part number and get back to me. If they are the ones you need I can sell them to you at dealer cost!
Old Jul 17, 2004 | 05:07 PM
ben73's Avatar
ben73
Ok, here are the part nos. and prices from when i did this 6 months ago:
17120070 LIFTER x 16 @ $12.56 = $200.93
12550002 GUIDE x 8 @$2.50 = $19.96
14101116 RETAINER x 1@$8.42 = $8.42
This is something you could only do as a part of a complete teardown/rebuilt, as there is quite a bit of grinding to do around the tops of the lifter bores to accommodate the guides.
The lifters are not difficult to obtain, I got mine via mail order from P&G Chevy.
You will also need to install a thrust button on the front of the cam and set up the end float to somewhere between 0.002 and 0.008" .
A rigid timing cover is also required, I used an alloy one.
I have pics of my valley with all this stuff installed, i could find them and post them if you are interested.. Its a pretty straightforward job, and works like a charm.
Oh, the base circle size of the cam is also important so that the lifters don't sit too low in the guides.. I have notes somewhere with all the measurements I took..
Ben.
Old Jul 17, 2004 | 07:45 PM
383 tpi's Avatar
383 tpi
Ben.
Thanks, also are the lifters from a v8 or v6? thanks for your help
Old Jul 17, 2004 | 11:53 PM
ben73's Avatar
ben73
They are from a V6, I think they come from a 60 degree V6??
I don't know much about chevy V6's. I am in Australia and they have never been available here....
Old Jul 22, 2004 | 08:44 PM
383 tpi's Avatar
383 tpi
Default Roller lifters
if you have part # 17120070 i am sure we can make a deal, once again thank you for the help
Old Jul 22, 2004 | 10:24 PM
comp's Avatar
comp
what about the spider????
Old Jul 23, 2004 | 12:26 AM
ben73's Avatar
ben73
The 'spider' is:
Old Jul 23, 2004 | 01:10 AM
comp's Avatar
comp
The 'spider' is:
sorry,i have parts but need more info on install
Old Jul 23, 2004 | 09:42 PM
comp's Avatar
comp
no links to a how to ??????
Old Jul 24, 2004 | 10:29 AM
comp's Avatar
comp
i have ???? all the parts from a "roller" block need info to instill in earller
Old Jul 24, 2004 | 02:43 PM
SBNova's Avatar
SBNova
COMP- if by saying " all the parts from a roller block" you mean including the factory V8 roller lifters- they wont work. Otherwise the spider and figure 8 things will work. Toss the front mounted cam retainer- you cant use it without machine work. Grind the block for clearance around the figure 8's when theyre placed on the lifters. The spider must have three bolt holes tapped into the center of the valley- right into an oil galley so be carefull. Thats all. Somewhere there is a link to some pics of all this but I dont have it anymore.
To conversion 86 block to roller
Old Jul 24, 2004 | 05:02 PM
Coupe89's Avatar
Coupe89
Dont forget the cam button....
Old Jul 24, 2004 | 11:41 PM
comp's Avatar
comp
i thought i could grind clearance and use the V8 rollers
Old Jul 25, 2004 | 11:21 AM
comp's Avatar
comp
anyone??????????????????????
