MAP & performance upgrades??
Therefore, if I do anything to increase airflow, the motor will run lean? Is this right?
What can be done with this earlier system to enhance performance?
I was thinking of valve springs and 1.6 rr's as an easy upgrade without taking the whole motor apart. I've heard it's good for an honest 20hp if the calibration is right.
Most of the stuff has to remain stock due to emissions testing. (like manifolds, converters)
I'm tearing into this thing in the coming week with the whole dynaspark/miezere installation.
You can make several changes that will not affect the fueling. You can improve your exhaust system by adding headers and a catback, and a cold air intake, slightly larger TB (52mm). Doing these modifications does not significantly alter the VE of the engine. Meaning this will not significantly alter the fueling in a way that the ECM cannot compensate.
Now once you go in and install a different cam, now things change. Installing a cam does change the engines VE significantly and this will require a custom chip to alter the fuel curves.
If it's not going to throw any extra fuel - then there will be no additional power.
So - without planning on the computer chip enhacement - don't bother with the mods.
I have been running 14# fuel pressure. The spec for the Crossfire is 9-13#. Last week in an effort to pass a smog test, I dropped the pressure to 10.5#. I decided to leave it that way for Friday night's racing to see if "lean is mean". My ETs were off slightly, until the DA dropped below 7200'. Then is slowed down, BIG time. I just came in from setting it at 15#, a pound higher than I've been running. Next Friday night will be interesting.
The SD system measures the manifold pressure, but especially at WOT, it has no idea of the atmospheric pressure. At so many TPS and MAP volts it goes into the PE mode which has injector pulse widths and the time curve preprogrammed. Even on carbed cars, headers can make re jetting necessary.
MY experience, confirms tjwong's statement that the modifications will make the car faster, but I think the original poster has a legitimate concern. Those modifications won't work to the maximum until the ECM is programmed to work with them. My fuel pressure adjustment is merely a crutch, to test my theory, but I'll take bets.
All this time *I* thought my car ran pretty good. It looks like I've left something on the table.
RACE ON!!!
