Best Scan Tool
Old Jul 19, 2004 | 10:58 PM
JA94vette's Avatar
JA94vette
Default Best Scan Tool
I'm new to the forum and had some scan qestions. What is the best scan tool on the market for a 94 vette? I was considering something PC based so i could also do tuning. Is there any software out there that does both? And what kind of price are we looking at? I really appreciate any information you could give me because i'm currently battling the Service Engine Soon light and a rough idle. I'm pretty sure its a sensor but i'm tired of paying $65 for a diagnostic when I could just purchace my own scan tool. Thanks again.
Old Jul 20, 2004 | 11:00 PM
JA94vette's Avatar
JA94vette
Does most of the diagnosic software such as tunercats and others scan trouble codes?
Old Jul 24, 2004 | 12:12 AM
gbody5's Avatar
gbody5
Check out the FAQ at the top of the forum, many options there. Moates.net has just about everything you need one way or another.
Old Jul 24, 2004 | 12:58 AM
tjwong's Avatar
tjwong
Tuner Cat does not offer a scan tool, for tuning the PCM or redoing a calibration in an old prom its great. For a scan tool you can use Datamaster, check it out at:
www.ttspowersystems.com
www.akmcables.com
You will need a communications cable to use with the software and it is available from Andy at AKM cables. He also sells the Datamaster software, which you can download a copy from the TTS site. You can use it 20x before you have to register it and pay for it.
Old Jul 25, 2004 | 07:12 PM
h rocks's Avatar
h rocks
http://forums.corvetteforum.com/show...post1547853920
Old Jul 27, 2004 | 04:50 AM
K2356's Avatar
K2356
Default Scan tools
Well there is plenty of differnt scan tools availible on the market. Prices range from $50 up to $5000 + If your a novice backyard mechanic you could get a simple code reader which will spit out a code and then you go to the service manual... look up that code # find out what it is and how to fix it.and these code readers will set you back about $50 to $150 a step up from this is a scan tool which will display more then just a code #,(something that will display data parameters such as Oxygen sensor values,TPS data,Map sensor data etc etc..) These scanner can range in price from $200 on ebay to $5000 + some of the better ones that will work on a 94 vette are, OTC's 4000 enhanced,or the snap-on mt2500, the snap-on scanner is real user friendly and you can get a trouble shooter cartridge that kinda holds your hand leading you through diagnosis. Another Option is to get something like a scan tool program with a pc or palm pilot interface.(example EASE diagnostics) you need to buy the program and the necessary cable hook up for your particular vehilce. These programs work great but for a novice mechanic you might be just looking at a bunch of #'s and data wondering what is right and what is wrong. Of course there is the Tech II which is a GM (Factory) scan tool which you can also buy, but now were talking $2500 + but of course this would be the Best scanner for your vechile, which would give you great bi-directional capability's. If you want a honest opinion,I would look for a snap-on scanner on ebay updated to at least 95 with the necessary GM cable of course. This scanner can fix id say 95%+ of your problems with nice user-friendly functions. If your not a novice mechanic and more of the profressional automotive technician and money isnt a issue.. then look a snap-on scanner or Tech II or even the PC based EASE diagnotics program. Hope that helps.
To Best Scan Tool
