How hot does a header collector get?
Old Jul 21, 2004 | 01:16 PM
RedZR's Avatar
RedZR
Default How hot does a header collector get?
Gang,
Anyone have an idea as to how hot the exhaust system gets where the header collector connects to the exhaust pipe- this would be on a car with no cat converters- just headers and pipes.
Thanks,
Dan
Old Jul 21, 2004 | 01:47 PM
Nathan Plemons's Avatar
Nathan Plemons
Much hotter than you would want to touch, but generally not hot enough to keep a non heated 02 working.
Old Jul 21, 2004 | 02:24 PM
RedZR's Avatar
RedZR
500 degrees???
600 degrees ??
1000 Degrees???
...any thoughts?
Old Jul 21, 2004 | 02:27 PM
Nathan Plemons
Sorry, best I've got is damn hot.
Old Jul 21, 2004 | 02:35 PM
Arisa's Avatar
Arisa
Just grab an IR temp gun & shoot it to see. If I had to guess......between 400* & 900*. Nathan said it best....damn hot.
Old Jul 21, 2004 | 03:33 PM
Nathan Plemons
Temperatures also depend on the header coating if any. A header that is coated on the outside only will be cooler than an uncoated header. A header coated inside and out will be cooler still.
Maybe if you could tell us why you're wanting to know we could have some pointers / experience with it. Perhaps you're looking for a good place to stick an EGT sensor?
Old Jul 21, 2004 | 04:02 PM
RedZR's Avatar
RedZR
I am painting the header collector so it will not rust and was curious as to what heat rating I needed on the paint.
Thanks all !!
Dan
Old Jul 21, 2004 | 05:20 PM
1990dtgL98squared's Avatar
1990dtgL98squared
We used 1500 degree VHT spray paint on the side pipes and headers of our Cobra. It lasted about a year, then we recoated them.....kept doing that till we ceramic coated them.
If you afford them, ceramic coat them!
The paint will last about a year, unles you drive in alot of rain/snowny coditions. If you're willing to paint them ever 6 months, go for it, but from someone who went through it, you can't beat the ceramic coating.
Just my .02
Old Jul 21, 2004 | 05:49 PM
ffvetteman's Avatar
ffvetteman
I don't think the paint will work. I used 1500 deg paint on my exhaust tips and it didnt hold up more than a year.
The collectors are alot hotter than the tips.
Ceramic coating I think would be the best bet. Paint will work but wont last long at all.
To How hot does a header collector get?
