Trying to get to door lock control module
Old Jul 23, 2004 | 04:00 PM
dwestsr's Avatar
dwestsr
Default Trying to get to door lock control module
I posted recently about cycling door locks on my 86 coupe and I have narrowed the problem down to a bad door lock control module. It is located under the passenger side instrument panel. But , I can't figure out how to get to the darn thing. How do you remove the lower carpeted panel. I removed the front panel ( mine was replaced with an after market piece to replace the "cushion") and it is not under there. Anyone ever replaced their doorlock control module? I have the replacement; just can't find the original . Please help!!1
Old Jul 23, 2004 | 05:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On my '88 you remove the screws along the front of the hush panel, drop the panel and remove it.
If you need to remove the bread box, I believe you will need to pull the dash pad too.
Old Jul 23, 2004 | 07:06 PM
nobodyunknown's Avatar
nobodyunknown
On my 84 its behind the information center.
Old Jul 24, 2004 | 11:14 AM
dwestsr's Avatar
dwestsr
I think the door lock module is near the ECM. How do you get to that? What do you have to remove?
Old Jul 24, 2004 | 03:57 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If your talking about the theft deterent module, it's behind right hand side of I/P
well, thats what my manual says
Old Jul 25, 2004 | 09:35 AM
dwestsr's Avatar
dwestsr
Yep, that's the one. Does anyone have any pics? I took my cover off but I don't see the module i'm looking for.
Old Jul 27, 2004 | 03:39 AM
AGENT 86's Avatar
AGENT 86
Whats the black box behind passenger side dash panel
To Trying to get to door lock control module
