Help please
Old Aug 2, 2004 | 08:09 PM
Chosen Won's Avatar
Chosen Won
Default Help please
Hi guys, long time no post. I have a 90 Vert, and when I got in her this morning, the passenger side window wouldn't work. I checked the fuses and everythings fine. Any suggestions? I wanted to ask on here before I took the door panel off. Thanks guys.
I posted this in the general forum earlier and got no response in 4 hours, so I decided to try here.
Old Aug 2, 2004 | 08:36 PM
comp's Avatar
comp
test power to switch. use a jump wire (fused) to motor to test and run up
Old Aug 3, 2004 | 01:50 AM
K87ZZ4's Avatar
K87ZZ4
Assuming you don't hear the window motor run when you move the switch (which could mean the toothed rail is broken), I'd follow "comp"'s suggestion to put power directly to the motor to make sure it's working (if it is, the switch is bad).
Old Aug 3, 2004 | 10:27 AM
Chosen Won's Avatar
Chosen Won
I am not hearing any noise from the motor at all. That is why it is so strange. But it did rain really hard the night before, and the water comes in right over the switch. Anybody know how much the switch will run me? Is it possible to disassemble and clean the switch?
To Help please
