Will a high voltage condition cause any real problems?
I replaced the alternator last week, and the new one just took a crap... SES... Check gauges... the volts were pegged - 17.7!!!!
Will this cause any other real problems? It did it like a block from my house, so I buzzed STRAIGHT home and parked it... turned everything off (ac/stereo/lights) so as to not anger it more as I drove home.
That sounds like your regulator may be somehow grounded or is not working properly. One way to test an alternator for charging is to put a small screwdriver in a hole on the backside of the alt. The Haynes manual shows it. This will cause your alt to go to 17+ volts. again this is a test to see if alt is charging but since yours is charging 17.7 by itself then it has to be defective or grounded somehow.
17.7 volts for the several blocks you drove won't hurt your battery. But if smoke comes out of the dash, the MOV (metal oxide varistor) that is on the power supply board in your cluster could overheat and burn up.
I just got back from the Kragen... the alt passed their tests, but, it is also a cold alt... so heat could change everything.
I am going to check all connections in the AM and make sure the harness to the alt is ok, then reinstall and drive. If it goes nuts, I will limp over to the parts shop. It's no more than 3 miles to there from my house, so it won't be a real issue... I will be nearby anyway.
It isn't the battery!!!!! The voltage regulator in the alternator maintains 14.7 volts output even with the battery disconnected !!!!!
You have an alternator problem if its output voltage is 17+ volts.
that's my thinking, however, the dude at the parts shop suggested the connection to the alt might be bad, so, at the very least, I will check that.
my guess? the voltage regulator is bad, but its failure rate increases in relationship to tempature.
Now that you've got the car home, time to do the following...
Disconnect the belt that turns the alternator and other accessories. Using an accurate DMM, check the voltage at the battery AFTER you've started the car. (It won't hurt to run the car for a minute or so without the belt) What is your voltage? Should be 10 - 11 volts; remember you're using battery power. Next, re-install the belt. Check the voltage again. If you're over 14.5 Vdc, you've got a regulator problem. The electrical components, computers and the like, aren't designed to withstand voltages of above 15 Vdc for extended periods of time. Internal damage may occur causing weird electrical problems in the future. You did mention that you purchased the alternator from Kragen. I've heard this type of story way too frequently about their parts. I would recommend using one of the AC Delco reman's. from one of the online vendors. I purchased one from GMPartsDirect for my '96. You've heard the old adage: "you get what you pay for".
That's pretty much what I was going to do (I have a Fluke DDM).
However, getting what I pay for, and what I can afford right now, are diametrically opposed! This alt is a stop gap until I can afford to get a new or remanned GM unit.
Thanks for the tips!!!
Interestingly enough, I got the same brand (OEM) from Advance Auto about 3 years ago to replace my starter, and it's going a-ok!
I went through the testing process that mvmechanic so kindly wrote down. The battery seems ok. It was hitting 11.7vdc on my Fluke.
So... I reconnect everything... start it up. First, the alt is slow to generate power at low RPM. So, I gas it a bit. What happens next is most exciting.
As the revs climb, so does the voltage... at a constant 1500rpm, all it took was about 15 seconds and I was back to 17.7vdc and a high voltage warning. Neato, eh?
I then shut everything down, waited a moment then refired the car. This time, the voltage is stuck at 12.2vdc and dropping! I shut it off at 11.9vdc.
Up. DOA voltage regulator.
Last night, when the dude at Kragen was testing it, I asked at what RPM was this tested at, and he didn't know. My guess? no more than 600rpm. And it's fixed.
Off I go to Kragen again. My neighbour across the street is going to run me up there!
Thanks for all the help! I will keep you all posted!!
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
If you run most modern alternators with the battery disconnected you will destroy them and possibly do other damage to the car. Removing a cable to check charging was never a good idea and now it is a definite no-no as it can cause voltage spikes which can damage electronic equipment. Glad to hear you got it whooped, Bogus.
I agree that it is the voltage regulator. If you have a connection problem this will increase resistance and reduce the amount of voltage you will get in your charging system. Without the voltage regulator you will see higher voltage than 14.7. You may be onto something with the idea of heat affecting the way the problem shows up. Let us know what you find. Good luck.
