Idle issue...input please
problem worsens.. IAC has been cleaned out, fuel pump and filter are
recent. Adjusted TPS, set base idle, no go. The 02 was replaced a couple
of weeks ago, the TPS a couple of days ago.. Problem started when TPS
was replaced. What can I do to narrow down the problem?
Few things are worse than a car with hunting/crappy idle.. Rather drive
my commuter and thats pathetic.. Please help.
This is an 85, stock, no mods...
Same thing, throwing a code 22 and idle will not drop.. Check Engine
light comes on, then goes out, then on again at about 90 second
intervals. Cleared codes, started up and idle jumped up to 1300
and light is back on, code 22 is the only code... Any ideas before
I enter into this years demolition derby? ( I am not kidding)...
This really gets my goat as the original TPS literally fell apart
when I took it off the TB...and the car ran much better with no
light.. I put two brand new parts in and all hell breaks loose..
Only GM...
If so my friend, you have a vacuum leak.
I'm speaking from experience. My 85 had a hunting idle that was driving my crazy for a year. What I learned from practical experience and from reading the forum is that sometimes we become too dependant on the ECM to tell us what's wrong instead of following our real world experience.
Shotgunning parts isn't going to help. Drop by your local Autozone or equivalent and get yourself a intake gasket set. Then remove, clean and replace all of the top end gaskets. That will fix your hunting idle.
Only GM...
Why all the high blood pressure? You will find what you need to fix this...it's no biggie. I assure you that given the proper description of the symptoms, the details of the car (ie. year, auto manual etc. mileage etc. etc.) you will have adequate feedback from Forum members. Now, obviously it's related to the removal of the "old" working parts, and your install of the new parts. The obvious questions are: a) did you in fact get the proper TPS? The parts stores aren't always right. Yours needs the adjustable one...sounds like you have the correct one. b) are you convinced that it's adjusted correctly? Did you use the jumper harness made for that job, or did you use a home made setup? c) you mentioned that you cleaned the IAC...was it removed? If so, did you follow the factory procedure for resetting it? d) you mentioned that you set the "base idle"...not sure on an '85, but it's usually controlled by the computer. IF yours is, then something changed that required you to use the set screw on the throttle body. d) are you sure that the O2 is properly screwed in, and there's no air getting to it? e) have you driven the car an ample amount of time to have the computer relearn? Triple check your work, have a beer, chill, and give us more details.
I was more or less cleaning up and removed the TPS when I noticed it
was grinding when moving the lever, then the arm came out of it. It did not work after that, hence the replacement..I have also put a vaccum gauge on the car and it looks normal. No jittering or dropping, holds rock solid.. Also, even if idle is bad, the ECM should be able to
at least drop it below 1300 rpms.. Thats my biggest issue now as it is
a new problem that did not previously exist. Will a misadjusted TPS
set a code 22?
was grinding when moving the lever, then the arm came out of it. It did not work after that, hence the replacement....Also, even if idle is bad, the ECM should be able to
set a code 22?
The 5 volt reference is gray, so put your meter on it and wiggle the harness. The return is dark blue and shorting it to the reference should set a 21 which would mean that the wiring and ECM are ok. Ground is spliced into the air temp and coolant temp sensors. You're not getting codes for either of those, so it's probably ok. I'd really suspect the connection is funky though. Also, if you disconnected the IAC with it running or readjusted the minimum idle, be sure to depress the accelerator when starting. Let it run for 10 secs and then turn it off. That should get the IAC back to normal.
We are all good.. Readjusted TPS and we are all set.. Idle is rock solid
and car runs great.. I tell ya, that TPS is sensitive as all hell but it works.
Getting bum parts off the shelf doesnt help either.. Thanks for the help.
