Roll your own dyno
Old Aug 3, 2004 | 12:07 PM
C10 JDR's Avatar
C10 JDR
Default Roll your own dyno
Found this, thought you all might find it interesting.
http://yarchive.net/car/horsepower_measure.html
Old Aug 3, 2004 | 12:12 PM
Red Tornado's Avatar
Red Tornado
John, thanks for the link. The 1rst 3 words in your subj line got my immediate attention
Old Aug 3, 2004 | 03:49 PM
JCD's Avatar
JCD
That's an interesting concept, I wonder how timing variations would mess up the calculation...
Old Aug 3, 2004 | 07:46 PM
C10 JDR's Avatar
C10 JDR
Brad - you're a rascal you are, to much listening to that nasty loud guitar music.
JCD - estimate your timing error, do the math(s) for the lowest and highest numbers - there's your possible error.
From what I have read about different brands of dyno, you probably will be just as accurate, plus you can calculate right down to tickover(ish) revs if you want
Old Aug 3, 2004 | 08:06 PM
hngacurv's Avatar
hngacurv
Interesting
Old Aug 3, 2004 | 09:16 PM
86_Vette's Avatar
86_Vette
It is mathematically sound. I don't think timing varations will effect too much on the calculations. Unless your reaction time is really poor. But even then, if you do several runs it should average out pretty close.
Old Aug 4, 2004 | 06:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The best you could hope for is about a .25sec reaction time, so accuracy on a 5sec time measurement would be about 5%.
For a peak CHP measurement I prefer to use trap speed and launch weight. So long as you can get consistent launches, this will work fine and you can even normalize results for weather conditions (you realy can't compare data from week to week without normalization). I think this method will be good to 1% or better. I've compared this method to chassis dyno data taken 15min apart and, assuming 17% DT loss (with my A4) the numbers for peak HP were dead on.
If you want a torque curve a chassis dyno would be the next best thing, though it will only give around 1/2 the curve if you have an A4.
Old Aug 4, 2004 | 07:52 AM
Red Tornado
yup, that would be me!
To Roll your own dyno
