Comp Cam Question
Old Aug 4, 2004 | 10:02 AM
drumboytroy's Avatar
drumboytroy
Default Comp Cam Question
Hey guys. I have installed a Comp Cam (CCA-08-300-8) in my L98. Is there a difference in the "Advertised" duration and actual duration of a camshaft? I just got the engine back in the car last night and have several other mods also so it will be a while before she's ready to crank. I was wondering what kind of idle I might have with this cam. Will it sound pretty much stock or maybe a little lopy? Here are the specs:
Roller Cam
Advertised duration: 262 intake/264 exhaust
Duration at 0.50 in. 206 intake/210 exhaust
Gross valve lift: .450 in. intake/.480 in. exhaust
Lobe seperation 112 degrees
Thanks guys, Troy
Old Aug 4, 2004 | 10:36 AM
jeffie8696's Avatar
jeffie8696
The only real measurement you need to compare cams is @.050 lift at the valve with stock rocker ratio, usually 1.5 and overall valve lift. The cam you are using should give you some rumpety rumpety at idle but a properly tuned engine should respond to it very nicely. The cam we used is crane 214/222deg at .050 with .488"/.509" (intake/exhaust) , it has a very rumpety idle ,but with the mods (Edelbrock heads etc etc) it runs wicked scary fast. and the idle is a steady rumpeta rumpeta that shakes the car at 600rpm.
Old Aug 4, 2004 | 10:41 AM
tjwong's Avatar
tjwong
Roller Cam
Thanks guys, Troy
Advertised and duration are two different measurements. Advertised is taken at about .006 lift and the other at .050 lift. It is just two different means of measurement. But the measurement at .050 is more meaningful to most as this represents more so as to what the cam really is. With what you have given the engine will have a very stable idle with your specs. a 206/210 is a very mild cam.
Old Aug 4, 2004 | 11:27 AM
mos90's Avatar
mos90
that cam is not more that a stock lt1 cam.
Old Aug 4, 2004 | 05:41 PM
jeffie8696's Avatar
jeffie8696
In the past unscrupulous cam grinders would post "advertised" duration using different valve lift measurements, .001", .003" etc therefore the @.050 is used to compare cams today. If you would care to send me your current engine configuration I would be happy to run it across Desktop Dyno and give you a "reasonable" estimate of the power you will be making.
Old Aug 5, 2004 | 09:00 AM
drumboytroy
That would be awsome man. I appreciate that very much.
Here is what I've done so far.
1987 L98
Edelbrock Performer RPM heads: (60859)
Comp Roller Cam (CCA-08-300-8)
Roller Lifters, hydraulic
Summit Racing Roller Rockers: (1.5 ratio)
Edelbrock High-Flo T.P.I. base plate intake: (#3860)
Stock TPI runners, plenum, injectors, and throttle body: (48MM)
Accel HEI Super Coil on distributor
Hedman Ceramic Coated long tube headers: (H68446)
Straight dual exhausts
K&N Hi-Flo air filter with breather lid cut out
Air Foil in throttle body
Removed A.I.R. pump and components. Replaced with pulley
180 degree thermostat
Thanks a million man!!
Troy
Old Aug 5, 2004 | 09:05 AM
Red Tornado's Avatar
Red Tornado
Troy, since you're going to all the trouble, may I recommend the Lingenfelter 211 cam for your application.
Old Aug 5, 2004 | 09:17 AM
drumboytroy
Thanks bradvette. This cam was already in the engine when I bought it. This engine is to hold me over until I build my 383
stroker. Would the Lingefelter 211 be a cam to consider for that application?
Old Aug 5, 2004 | 06:39 PM
jeffie8696's Avatar
jeffie8696
Troy I think I can use some of the info you gavebut you have a few variables that the program doesnt recognize so the results will be just ballpark. "Your results may vary". I do need a compression ratio and overbore if you have it. Jeff
Old Aug 5, 2004 | 07:52 PM
drumboytroy
Hey Jeff. I appreciate any info even if it's "ballpark". It'a a stock 5.7, no overbore and the comp ratio is 9.5. Thanks again, Troy
Old Aug 5, 2004 | 08:15 PM
jeffie8696's Avatar
jeffie8696
I will get on it soon as possible but I do not have internet access daily, sorry. :blush:
Old Aug 5, 2004 | 09:35 PM
drumboytroy
At your convenience. Thanks man.
Old Aug 6, 2004 | 04:03 PM
joalyons's Avatar
joalyons
I have the next biggest Comp Cam, as I recall its 488 / 509 @0.50 and it has a little rumpty rump, I think its just right. If I remember correctly this cam has a slightly lower lift and slightly longer duration than the ZZ9 cam. The longer duration is why you get a little more lope and may also be a problem with Smog check. I have not had a real problem (either in AZ or NC) but its real close at idle.
Old Aug 6, 2004 | 06:23 PM
drumboytroy
In July of 2005 they will start emissions testing in all Tennessee counties. I will have to put the cat back on my car before then. I have straight duals right now and am considering 2 cats,....one for each side. Hopefully the cam won't be too much. From what I hear and read it's on the mild side. Thanks man.
Old Aug 9, 2004 | 12:32 AM
jeffie8696's Avatar
jeffie8696
Yo sorry for the wait. Troy it looks like you have a nice combo. About 460 ft lbs @2000 holding to about 4000 then tapering off . Horsepower should be 350@4500 holding to 5500. Typical TPI power curves according to Desktop Dyno.I think you will like it.
Old Aug 9, 2004 | 10:39 AM
BIG JIM 54's Avatar
BIG JIM 54
And you can believe what JEFFIE has to say.
He was my Vette mechanic before he moved back to Backwater, USA. He ported my heads and base intake and I did the plenum work and added the 52mm TB. And for a light-cammed motor this thing is quite a ride and it passed CA smog with flying colors.
Jeffie's the man!
BTW, Desktop Dyno 2000 says 372HP at 4000 RPM and 445 ft.lbs. torque at 3500 RPM. I have a CompCam as well. Cam # is 501-8.
BIG JIM
Old Aug 9, 2004 | 08:37 PM
jeffie8696's Avatar
jeffie8696
Big Jim, is my electric motor mechanic, I think???
To Comp Cam Question
Old Aug 12, 2004 | 10:09 AM
drumboytroy
Hey Jeffie,
Sorry I didn't get back to you sooner. Iv'e been on vacation all week. The figures you gave me sound encouraging! It was actually what I was shooting for pretty much. I'm about to fire this baby up. I can't wait to see how she does. Thanks again for the info and I'll be in touch and let you know how things go. Have a great day man! Troy
Old Aug 12, 2004 | 08:18 PM
jeffie8696's Avatar
jeffie8696
Troy, anytime dude. Playing with my Desktop Dyno program is about the only hobby I have left. (I hate being unemployed)
Old Aug 13, 2004 | 09:16 PM
drumboytroy
I've been there before man....it does suck. I hope you find something soon. Good luck and again thanks for the info. By the way, I cranked her up today for the first time and she sounds awsome dude. Sounds just like I hoped it would. Later man.
