Odd problem with A/C and throttle.
Old Aug 8, 2004 | 01:41 PM
Shaun R's Avatar
Shaun R
Default Odd problem with A/C and throttle.
For some reason on my car when the A/C is on and I give it more than 25% throttle, rough number, the air quits coming out on the top vents and starts blowing out on the bottom. Then as soon as I back the throttle off it quits coming out the bottom and returns to the top vents. This happens no matter which setting the controls are on and I also have auto ac if that makes a difference. Suggestions?
-Shaun
Old Aug 8, 2004 | 01:52 PM
JackDidley's Avatar
JackDidley
Check the vacuum check valve on the intake Its plastic and they go bad just for the fun of it.
Old Aug 8, 2004 | 01:58 PM
Shaun R's Avatar
Shaun R
Would this cause some odd random performance and gas milage problems?
Old Aug 8, 2004 | 02:04 PM
JackDidley's Avatar
JackDidley
Should not have a big effect on the performance. But it can be a vacuum leak. Have a look and if the check valve or the line is broken you can plug it up till you get a new one.
To Odd problem with A/C and throttle.
