D36 Gears
Old Aug 11, 2004 | 11:26 AM
jburnett's Avatar
jburnett
Default D36 Gears
I've got a D36 I'm building for a customer/friend and he's wanting to run 3.54's (I've usually done 3.73's) and the only set I've found in that ratio is Richmonds... Any other sources off the top of your heads?
-Jeb
Old Aug 11, 2004 | 11:47 AM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Drivetrain Superstores lists a thick set of 3.54s by Precision. And the Motive Gears catalog (pg 14) lists 3.54s in both thick and regular. I don't know if either Motive or Precision actually manufacture their own gears or if they just repackage Richmond's though...
http://www.drivetrainsuperstores.com...ail.asp?id=551
http://www.precisiongear.com/dana36.htm
http://www.motivegear.com/
